I had the older zigbee connection for the web portal but it kept having issues and finally just no longer worked. Several resets, moving the device closer, etc. was useless. So I decided to just run an ethernet line directly into the SE6000. My inverter did not have a RJ45 jack but instead the 8 pin ethernet terminal block. Having rewired my house from cat 5 to cat 6 I was actually comfortable with this.
I got everything setup and working correctly (I thought). But I can't seem to get connection to the monitoring portal to connect.
The message on the inverter shows a solid connection to my router with a valid IP address, gateway, you name it. Also in the LAN screen on the inverter it correctly shows all of it's 8 bit communications status' showing it's working right. But it still doesn't not show up on the monitoring portal as connected.
Do I need to do any further steps with changing over from zigbee to LAN? Again, I did configure Sever to LAN and it does now get a valid IP address from my router and I see it in the router as a connected device.
Any help would be appreciated.
