Hello everyone,
I'm having a PV the following system being installed in my house.
DC kW: 5.70
Modules: 20 LG Electronics 285 S1C-G4
Optimizers: 20 Solar Edge P300
Inverters: 1 Solar Edge SE5000A-US
The inverter will be located on an exterior side wall right next to the meter and the electrical panel as shown in the diagram below (shown in red). The area is open and accessible to anyone, in other words not behind a wall or gate. In the past we've had problems with kids opening the electrical panel and disconnecting the power breakers as a result we had to put a padlock on the electrical panel box. My concern now is with someone tampering with the easily accessible inverter. I've browsed thru the specs for the inverter but I do not see anything addressing how the unit can be made tamper resistant.
Does the inverter have to be in an open area such as this to be accessible to the fire department ?
I suppose the inverter location next to the main electrical panel is needed to keep AC power losses down, is that correct ?
Are there any security and/or tamper proof mechanisms built into the Solar Edge inverter ?
I can think of two other options to locate the inverter:
Option 1 - Green:
Option 2 - Blue:
Any comments and/or suggestions would be greatly appreciated.
Thanks,
gatorbill
DC kW: 5.70
Option 1 - Green:
- I can place the inverter inside the garage to make it tamper proof, but the main electrical panel is on the other side of the house some 70-ft away ?
- The DC run from the array to the inverter would need to penetrate the roof and go thru the attic to get to the garage, this would be a short DC run.
- The AC run could go up into the attic then run the length of the house until it got to the wall where the electrical panel is, but this would be a long 70-ft AC run.
- I have read that a long AC run is bad because the voltage drop would require very thick conductors.
Option 2 - Blue:
- I can place the inverter in the back wall of the house where it will be behind a block wall.
- The DC run is now about the same as the current design.
- The AC run is now a little shorter than with Option 1 at around 30-ft.
- This is the master bedroom wall, does this inverted have a fan and is it loud enough to be a nuisance that close to the bedroom ?
Thanks,
gatorbill
