  • raymondalmeda
    • Dec 2010
    • 35
    How long will it take to fully charge my Batteries?
    Hi Everyone!
    I just need help in figuring out how long in "real time" will it take my batteries to be fully charge. Here's the deal:
    4pcs. 100w PV Panels @ 12v each and 5.71a.
    >I wired two of them together in series to make them generate 24v
    >In the philippines, we get an average of 5 full sun hours per day all throughout the year, so I'd be generating around 2000wh or 2kwh per day in an MPPT controller.
    I have 2pcs. 12v AGM batteries @100Ah each.
    >I also connected them in series to make them 24v @ 100Ah.
    >I know that with my batteries, I have 2400wh of stored energy (but I will only use 600wh out of it).
    Question: How long will it take my Panels to top of my batteries if ever @ the following states?
    70% SOC or 1680wh available=?
    75% SOC or 1800wh available=?
    80% SOC or 1920wh available=?
    Please share the formula as well if possible so I can compute it on my own in the future.
    Thanks!
    -Ameds-
    [URL="My starter solar setup"]http://www.facebook.com/album.php?aid=110199&id=1460868554&l=8dbb187d24[/URL]
    [URL="Video of my solar setup"]http://www.youtube.com/watch?v=xEq-6Lc3_SI[/URL]
    Well let's tech you to fish rather than give you food.
    If you are using a MPPT controller the maximum efficiency you can achieve is 66%. So with 200 watt of solar panels and 5 sun hours the most energy you can generate = Watts x Hours x .66 = 400 watts x 5 hours x .66 = 1320 watt hours so you were way off with 2000 watt hours because you did not account for efficiency.
    For the batteries to get a rough idea take the battery Voltage x Amp Hours = Watt Hours. So 12 volts x 100 AH = 1200 watt hours, and you have 2 batteries so 2400 watt hours of reserve capacity.
    By now you have all you need to know. All you have to do os factor out the watts to be left with time in hours.
    So if your batteries have 50% charge you need to replace 1200 watt hours. Your panels can generate 1320 wh with a 5 sun hour day or 1320 wh / 5 hours = 264 watts. So factor out the Sun Hours 1200 wh / 264 watts = 4.55 hours. The formula is w = wh/h, which means h = wh/ w, and wh = w x h.
    FWIW this tells me you do not have enough battery capacity for your system, you need another 8 batteries.
    • raymondalmeda
      • Dec 2010
      • 35
      This is great sunking! Thanks for the lesson! I appreciate it.
      I now understand it a lot better, two follow up questions though; how about a norman PWM charge controller? what is it's normal efficiency? it is close to 66% too?
      and also, can you explain to me (please) why I would need another 8 batteries in my bank?
      Thanks!
      -Ameds-
        At very best is 50%
        Battery capacity are deigned to have a number of days reserve capacity with 5 being the lowest number which actually is only 2.5 days of usable as you never want to go below 50%. Si if your winter or minimum production is 1320 wh as you have, Then the proper battery capacity = 5 days x 1320 wh = 6600 watt hours. So with a 12 volt battery would be 6600 wh / 12 volts = 550 AH @ 12 volts.
        Don't get the wrong idea that you have to buy more batteries, because you do not, it is just your system is a bit out of normal design parameters. Having a larger panel wattage than needed is not bad thing providing the charge current does not exceed C/8 for flooded lead acid batteries, or C/4 for AGM. Th ereal problem is having too small of a panel wattage whereby the charge current is to low to agitate the battery acid (bubble).
        • raymondalmeda
          • Dec 2010
          • 35
          Understood! So with my current panel wattage; it's just fine to add 8 more batteries tops?
          Thanks Sunking!
          -Ameds-
            Nah my bad. Currently you have 200 Ah 550AH is the max, or 3 more batteries.
            • tonygcan
              • 22
              Confused
              Shouldn't this equation read 200 watts x 5 hours x .66 = 660 watt hours?
              • tonygcan
                • 22
                Oh okay, sorry about that. He has 4 PV panels at 100 watts each.
                Okay thats why it's 400.
                Got it.
                • tonygcan
                  • 22
                  Got confused again
                  I was re reading this question and got a little confused.
                  Given: 5 hours of insolation X 400 watts X .66 = 1,320 watt hours
                  1,320 watt hours X 5 days = 6,600 watt hours
                  Shouldn't the next equation to figure out the Ah capacity of the batteries be
                  6,600 watt hours / 24 volts = 275 Ah since he is working with a 24 volt system?
                  In which case the total battery capacity would be batteries in series 24 volts with a total Ah capacity of 275 Ah?
                  Thanks for any clarification.
                  • Gdwats
                    • Jul 2017
                    • 207
                    Huh?
                    900W, 40A MPPT, 230AH FLA,24V Samlex 1500W
                    • max2k
                      • 819
                      Originally posted by tonygcan
                      Got confused again
                      correct if you mean Ah of individual cell in 24V battery- when connected in series the total Ah of the resulting 'battery' is the lowest Ah battery (cell) used. Since it doesn't make much sense to use cells with varying Ah for the same 'string' it is basically Ah of any one of them.
                      • Gdwats
                        • Jul 2017
                        • 207
                        Awesome. I was looking for all this info again to figure my next panel addition, with help I hope. I now have:
                        40A Renogy Rover 24V mppt CC.
                        4 x 100W 12v mono panels in series(more later).
                        4 x 6V Trojan T105RE 225AH flooded deep cycle in series(picking up next week).
                        Samlex PST1500 1500W 24V pure sine inverter(on route)
                        Second Samlex pst300W 24v pure sine inverter(on hand)
                        I think the smaller inverter will be needed when running under 1A at times as that puts the 1500W to idle. Can one safely run them simultaneously if not drawing more than 1500W total?
                        I have a 6hr full sun day, with noon right in the middle of it.
                        can anyone speculate as to how many more 100w panels would be min for this setup?
                          why are you buying expensive 100w panels @ $1/watt ? 250W panels are $0.50 / watt or less, and fewer wires to mess with
                          • Gdwats
                            • Jul 2017
                            • 207
                            Started with 2 at a space limited appt. Didn't want to mismatch, so here I am.
