Trying to figure out the voltage on the roof for various inverter types. My thoughts below. Could you please share your insights too? This is for Northern NJ with PSEG as utility supplier
1) String: Seems like all the panels are connected in series and then it goes to inverter. So if say 20 panels then each generates 30V DC(is 30V DC right, btw?) then total voltage coming down from roof is 600V DC which then goes to 600V to 110V AC (probably two phase) inverter on ground and then to AC grid.
2) Micro-inverter: At each panel 30V DC is converted into 110V AC (single or two phase) and then it goes straight to the grid. (No other central inverter on way to grid? Not sure? ) So power coming down from roof is 110V AC (single or two phase, not sure)
3) SolarEdge SIngle Phase Inverter (say SE3000A) with Power optimizer: How does this work? No idea at all. Is this string inverter variation or more of micro-inverter? It does have a big central inverter on the ground with power optimizer connected to each panel. Does the optimizer do any DC to AC conversion?
