Yeah a lot. Sun does not shine at night when you need heat in SD, you are buying power. Nor does a small 6Kw system generate enough energy to run a heat pump during most of the day. Generating electricity to use as heat is extremely inefficient on the order of 20% or less from plant to heat pump. Using NG at Point Of Use is nearly 100% efficient. Using electricity takes 5 units of energy to make 1 unit of energy from NG. Your way pisses away a lot of money and resources with much higher emissions.
So why do you advocate pissing away money, using precious resources, and a heavy polluter. You ought to be ashamed of yourself.
