Most Popular Topics
Questions to ask salesman about mounting racks.
I used Solarclam-p railless Mounts.
Saved me a lot of money compared to the Rail systems.
Solarclam-p.com
Cheers,You do not have permission to view this gallery.
This gallery has 1 photos.Comment
I was wondering about those edges too. That's just decoration? I thought it made the system look worse. I like the sleek look with the tiles removed under panels where the panels are flush with the roof. Is that flush install worse for roof wear? The look is nice in my opinion.Comment
A flush system will not affect the wear on the roof much either way, but it will result in much higher panel temperatures. That will reduce your output on all but very cold days and may lead to faster degradation of the panels if you live in a hot climate.I was wondering about those edges too. That's just decoration? I thought it made the system look worse. I like the sleek look with the tiles removed under panels where the panels are flush with the roof. Is that flush install worse for roof wear? The look is nice in my opinion.
The conventional wisdom for cooling is at least 4" off the roof, with no significant improvement once you go past about 6"SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
With respect to the height off the roof, be careful on sizing. My location is in high wind area. When I used the Iron Ridge Software a few years back I was limited on the roof gap. I believe 3" was okay but move up to 4" and they couldn't supply me a racking system to meet my wind requirements. There is calculation called wind uplift and that works against higher spacing. I think some companies are requiring edge sealing as way of getting around this.Comment
Since the biggest reason for increasing the roof gap for panels installed parallel to the roof surface is to increase the cooling air flow to the bottom of the panels, adding edge sealing to allow greater spacing is self defeating.With respect to the height off the roof, be careful on sizing. My location is in high wind area. When I used the Iron Ridge Software a few years back I was limited on the roof gap. I believe 3" was okay but move up to 4" and they couldn't supply me a racking system to meet my wind requirements. There is calculation called wind uplift and that works against higher spacing. I think some companies are requiring edge sealing as way of getting around this.
If you need clearance for wiring, plumbing, odd bumps in the roof, etc. , that is a different story.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I agree entirely with respect to edge sealing. I suspect that salesmen looking out for the bottom line are taking a cost savings with technical limitations and turning it into a selling point to unknowing consumers.Comment
Where there is a bird, there is a way. Photo of bird nests in between spike strips. flash tape woven into the nest too! 20160408_102618.jpg
Attached FilesPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
