Hi guys. I have been lurking around this forum for a long time now but this is my first post. Going through past threads has contributed immensely to my solar setup knowledge.
I am trying to setup a small off grid system with a 12v 200AH batteries, 1050VA Interter (With battery charging capabilities), a 30A Epsolar Mppt charge controller.
As to the panels, I have access to 2 240watt 24v poly panels and 1 220w 24v poly panel.
The panel config are:
PMAX = 240w
VMP= 30.5v
Imp= 7.78
VOC=37.7
ICS=8.42
I was initially going for a 24v system until I read here that the VMP at 30 would be inaquate for a 24v setup once heat and wiring loses are subtracted. I come from Nigeria where it can get real hot (31-38c) all year round. So decided to use a 12v system with an Mppt charger.
However my Mppt charge is 30A and has a Max. PV open circuit voltage of 150V and Max. PV input power of 520W.
Question is how best do I use my panels to get the most optimal results from the panel.
My plan initially is to connect 3 panels in parallel .. Or do I connect them in series of 2 as 3 might take it over the Max PV rating of the controller.
Also what is the expected current I could get using whatever setup is recommended.
Also my country Latitude is 10º00´ North of the Equator in this case, which direction is best to point the panel towards? I hear people in northern hemisphere generally direct towards the south. Will same apply to me.
I am a newbie never done a solar project before, however I have tried to do lots of learning and catching up. Due to the shortage of professional solar installers in my country I will be heavily involved in my setup to ensure things are done right (especially with the panel setup side of things)
I would also appreciate advise on the size of breakers both dc and AC I would need between panel and controller, controller and battery, battery and inverters, and Inverters and house, grid to
inverter.
Lastly, I read somewhere that the charge controller (the Epsolar Tracer 3215BN) has the capability to backoff once it detect the battery is being charged from another source (i.e Inverter) is this a general feature of MPPT controllers or just a feature of this particular controller.
Am sorry if my questions are stupid or I should have researched more. I have been on Google and on this portal for most of the past couple of weeks.
Also apologies for my English.
Thanks in advance
Well I lost one of the
EDIT:
Unfortunately I lost one of the panels (The 220W panel) had an accident while transporting to my premise
so right now I have 2 240watt panels with following specifications.
PMAX = 240w
VMP= 30.5v
Imp= 7.78
VOC=37.7
ICS=8.42
I have (for now) One 12 volt battery for the setup with the hope of increasing it to 2 in the near future. I had plans of going for a 24 volt system with a larger charge controller but that would go over my finances (which is already over the budget as it is) so I intend to move slowly.
With the 2 240w panels, if I connect them in series I could expect potentially around 40amps from them for my 12v setup. (kindly correct me if am wrong) which would be over the limit of my charge controller which has the following limitations
Rated battery current 30A
Rated load current 20A
does this mean I can not use a setup which would potentially push out 20A?
Also if I connect this panels in parallel what would be my estimated amount of charge current all things considered.
Thanks once again
PMAX = 240w
VMP= 30.5v
Imp= 7.78
VOC=37.7
ICS=8.42
inverter.
Thanks in advance
EDIT:
PMAX = 240w
VMP= 30.5v
Imp= 7.78
VOC=37.7
ICS=8.42
Thanks once again
