  • raymondalmeda
    • Dec 2010
    • 35
    12volts or 24 volts setup?
    Hello again everyone!
    Here's my dilemna now, I have these things just bought:
    4x 100watt solar panels 17volts @5.71Amp each
    4 x 12volts 100Ah (RC/20) AGM Deep Cycle Batteries
    Wellsee 40A solar controller (http://www.wellsee.cc/ProContent_Editor.aspx?action=94)
    1kva pure sine wave inverter
    I'm currently contemplating on whether I go for a 12v @ 400AH system setup or a 24v 200AH setup? In my previous post, I was asking whether my panels are enough to charge my batteries.
    Appreciate the help! Thanks!
    -Ameds-
    [URL="My starter solar setup"]http://www.facebook.com/album.php?aid=110199&id=1460868554&l=8dbb187d24[/URL]
    [URL="Video of my solar setup"]http://www.youtube.com/watch?v=xEq-6Lc3_SI[/URL]
    Your load demands factor heavily in the voltage decision. If you never have over 1,000w of load (including motor starting surge) then 12V would work. If you go above 1,000W -2,000w, then a 24V system is better, less amps at the batteries needed. Above 2,000w, consider a 48V system
    • raymondalmeda
      • Dec 2010
      • 35
      Thanks Mike!
      I will seriously consider your advice, my only concern is that: Won't a 24v system would make me worry less with the cable sizes and lenght? That's my only reason why I'm considering a 24v setup. Any thoughts on that?
      Thanks!
      -Ameds-
        Yes, a 24V system has more leeway with voltage loss, and cable length issues, but I would still practice some sanity with using proper sizes and lengths.
        • raymondalmeda
          • Dec 2010
          • 35
          With my current setup Mike, what wire size can you recommend if ever I go to the 12v route? No wire will ever go longer than 10 feet.
          Thanks!
          -Ameds-
            I've still got no idea what your loads (on the AC side of the inverter) are.
            120V or 240V inverter?
              The minimum size wire will be listed with the inverter instructions.
              • raymondalmeda
                • Dec 2010
                • 35
                240v mike! Total computed loads would be 500 - 600 watts for 4 hourds per day.
                -Ameds-
                • raymondalmeda
                  • Dec 2010
                  • 35
                  Unfortunately, the inverter did not specify the required wire sizes. That's why I was hoping on finding answers in this forum.
                  Thanks!
                  -Ameds-
                    What is the VA rating of the Inverter? 100 watts, 2000 watts, what?
                    IF your inverter does not specify the minimum size wire and breaker needed on the battery input, you need to find another manufacture.
                    • raymondalmeda
                      • Dec 2010
                      • 35
                      The Inverter is rated @ 1KVA, power factor of 87% so maximum continuous rating is 870watts, surge rating is 1600watts.
                      Thanks!
                      -Ameds-
                        Voltage Drop Calculator :
                          At 12 volt input you will need a 125 amp fuse and a minimum 1 AWG copper conductor.
                          At 24 volt you need a 60 amp fuse, and a minimum #6 AWG copper conductor.
                          • Remon
                            You looks like a specialist on this
                            • dinablaster
                              • Dec 2010
                              • 7
                              i am not good at this calculation but i learn that in school, P have bigger lost in 12 wires than same P in 240 wires and much smaller in 240 (50-60Hz)
