So, I bought a grape solar kit. It came with 2 single 100 watt panels, a charge controller,an inverter, and the wire and connectors. I have the panels mounted, and the charge controller and inverter mounted. I have a single 12v 95ah AGM battery. This is to power a light and a water heater in a chicken coop. It's too far from the house to run a line and, I thought this would be a great way to experiment with this. So, the book shows the wiring to run through a GFP, a disconnect, a shunt, and a battery disconnect. None of those things came with the kit. But they state that everything I need is here. I know little about this, and I am just learning. So here's my questions.
1. Do I need the GFP,shunt and disconnects?
2. Does the array go directly to the charge controller with the positive to the pv load and the negative to the common negative?
3. Do,I then run those out to the battery and then to the inverter?
4. Is just the one battery okay?
5. The wires have metal loops on one end. Do I need those loops or can I cut them off and crimp into the mc4 connector
After you're done chuckling (I know I am) please help me with some knowledge. Thanks everyone.
