Hi all,
I've read a ton here and have watched 100s of YouTube vids on solar (and wind) and I do have a few questions.
1. Panel side - I see many people placing multiple panels in parallel (with diodes of course) that have widely varying voltage and currnt ratings, and connecting them to a common charge controller. Doesn't this limit the overall performance?
2. Charging - I see many people with a common battery bank placing multiple charge controllers (of various capabilities) in parallel, either due to input voltage of capacity reasons of the solar feeds. Doesn't this make battery bank management a mess? For instance a "cheap" bulk controller from a starter system (and its own panels) running in parallel with a PWM charge controller of their new/improved "larger" system - both using the same set of batteries.
3. Solar Grid Tie - I have not seen much discussed about how to arrange systems in a way that the grid tie kicks in whenever the batteries are fully topped off. do some charge controllers have a separate output to connect the grid tie inverter?
4. Battery Grid Tie - I have not seen much discussed about how to feed battery energy to the grid in an automated way when the battery bank is underutilized in servicing the daily loads. If a person plans to use a certain amount of KWH out of the batteries each day but doesn't, shouldn't it go to the grid?
Thanks. Great forum.
Tom in MN
Tom in MN
