4.4 kW Solar PV Grid Tie System in San Diego
That's a good reference point thank you. The system I got installed is super efficient ducted mini split with (http://homeenergypros.lbl.gov/profil...lits-look-like) that is not my system but a point of reference. I got the following installed for any HVC nerd Fujitsu AOU24RLXFZ 24,000 BTU Multi Zone Heat Pump R410a Fujitsu ARU18RLF 18,000 BTU "Duct Type" Air Handler Fujitsu ARU9RLF 9,000 BTU "Duct Type" Air Handler So according to Fujitsu it takes about 30kWh per 9 hours of use per Air Handler (I have two one for my 3 bedrooms and 2 bathrooms, and one for my living room and kitchen) My goal is to come as close to zero'ing out the bill as possible. I am open to suggestions and thoughts, but this would be the, 'Honda' of the solar systems nothing fancy, quick ROI and gets the job done. (some may argue LG panels would be more 'Honda' like..)Comment
Get a reasonable estimate of your cooling load before you choose and don't oversize the system. Properly sized systems probably produce better comfort by keeping the humidity level down better than oversized systems. Long story. Basically, they do a better job of moisture removal by running longer. Also properly sized systems, will not cycle as much. Probably less wear/tear. Starting up is tougher than running. Finally, smaller systems generally cost less to purchase and operate. Oversizing A/C is not a wise choice. It'll cost more, probably break down sooner and the house will feel "clammy" and be less comfortable.Comment
ON that note, does anyone have an advice or experience with HERO vs. HELOC? Credit score is about 840 FWIWComment
Hey Albert,
Jumped up on my roof today to take a few pictures for you. Man it got dirty in a year so that's good to know if I was planning on doing Horizontal mounted panels.
Ya they seem cheaper than having Duro-Last come back out and make all kinds of punctures in my roof... Just talked with an structural engineer and he informed me that it was not recommended. My house was built in 1928...
(Edit -- Oh I see you have answered this last one already.)Comment
Hey Albert, Jumped up on my roof today to take a few pictures for you. Man it got dirty in a year so that's good to know if I was planning on doing Horizontal mounted panels. https://goo.gl/photos/1XrJbs5RGEL9DDJn6 Ya they seem cheaper than having Duro-Last come back out and make all kinds of punctures in my roof... Just talked with an structural engineer and he informed me that it was not recommended. My house was built in 1928...Comment
+1, if you haven't used HELOC, it's probably the best option. It's very flexible that you can pay it off anytime. In the draw period (first 10 yr normally), you only have to pay the interest if cash is tight. Also the interest payment is tax deductible using itemized deduction method.16xLG300N1C+SE6000[url]http://tiny.cc/ojmxyx[/url]Comment
+1, if you haven't used HELOC, it's probably the best option. It's very flexible that you can pay it off anytime. In the draw period (first 10 yr normally), you only have to pay the interest if cash is tight. Also the interest payment is tax deductible using itemized deduction method.Comment
Another Estimate
Hi All,
Here is my latest estimate. Comes out to about 4.50/watt but it's a pretty small system at 3,180... Thoughts?
SYSTEM DESIGN, PERMITTING & UTILITY INTERCONNECTION
System Design - Electrical Plans, Site Plan & Plant Location Drawing Municipal / County Permit Package & Inspection Coordination Utility Interconnect Application and Inspection Coordination Municipal / County Building Permit
No Special Permit Requirements
MAJOR SYSTEM COMPONENTS PV Module
Additional Panels Not Required
12 Hanwha 265 Watt Panels
Inverter
SolarEdge Grid-tie Inverter, 3.0 kW-AC
12 SolarEdge P300 Optimizers
Inverter Accessories
(No Accessory Selected)
Mounting System
ProSolar Mounting System & Structural Attachments w/ Tilt-up Kits
(No Secondary Rack Requirement)
INSTALLATION LABOR & MATERIALS
Installation Labor & Project Management
Installation Materials (wire, hardware, conduit, switches, branch circuit kits, etc.)Comment
No decided to wait a month or two after getting the A/C system, new doors and windows installed before making a decision.
Boy I'm glad I did, my bill last month while running the A/C 24/7 at 76 degrees was $89 bucks... The unit runs more efficent than the 4 box fans I was running in each window and the bill actually went down!!!!!
Can not say enough great things about Gabrial Carini:http://www.cariniair.com/about-us/ ! He installed an absolute killer A/C system in my 1920s North Park home!
-RyanComment
-RyanComment
