  • posplayr
    • Jun 2015
    • 207
    Originally posted by ButchDeal
    I only pointed out the SW / SSW as the OP originally claimed S when it was really SSE and as you showed that makes quite a difference in the production in a TOU situation.
    Not that it really matters if you re read what I posted, I did a quick pivot from 202deg to 225deg to achieve a solar production peak at 2 pm. I did describe the 202 degree point but went to 225 for the ease of TOU analysis.
    As it works out there are 3 hours between solar peak at 180deg, and so that point is 45 degrees from a 2:00 pm TOU rate transition.
    45 degrees = (2+1)hrs*360/24
    If I recall 180+45=225 is SW.
    Rereading the OP's comments about minimal shading morning or evening, he might be able to go even further to the west. As an example, considering strong afternoon sun to perhaps 6pm and a rate transition at 2; that is a 4 hr spread, splitting the difference would have a desired solar production peak at 4pm to grab the most of the peak TOU.
    75 degrees = (4+1) hours*360/24
    180+75=255 degrees. That is along ways from 158 deg (97 degrees).
    All that would need vetting with something like PV watts, and 255 may be too far, but it sure seems like from a TOU perspective 158 is close to 90 degrees out. Is it serendipity that there is another roof already 90 degrees out?
      Originally posted by posplayr
      I guess sensij did not come back to answer the questions I posed.
      I've been busy. I tried to follow a lot of the nonsense since my last post, but it makes my head hurt. Sorry, I haven't been able to turn that into a productive response.
      With respect to TOU, under SCE's TOU-D-A plan, a 158 deg azimuth, 45 deg tilt system might produce $2951 of credit annually. At 45 deg tilt, the maximum revenue a 7 kW array would produce is $3132 under the same assumptions (azimuth for that case is 195 - 200 deg), so it pushes the annual difference with respect to flush mount from the $70 base case I described earlier to $181. That assumes you can even fit the 7 kW array side tilted on the roof in the unshaded portion, which is not assured given the extra space between rows required. It also assumes the roof itself won't cast any shade on the obliquely mounted panels, which is also not assured, especially at 12:12 pitch.
      If custom mounting is on the table, a custom tilt could also be considered, I guess. The max revenue I can get out of this location is at 195 deg azimuth and 32 deg tilt, good for $3206 annually. That same revenue would come from increasing a flush mount array from 7 kW to 7.6 kW... basically, adding two 300 W panels, maybe $1000 of costs, or maybe $2000 installed. There would also not be the roof/self-shading problems to try designing around. Does anyone really think the custom engineering, shade analysis / mitigation, more complicated mounting system would cost less than $1000? I don't.
      Also, back to the questions the OP actually asked, I was wrong to say that all panels would be equally good. On a steep roof, sticking with 60 cell panels for ease of handling might have some benefit to the installer.
      Edit: There was an error... the baseline run was at 158 az/20 deg tilt instead of 158/45 deg tilt. The numbers have been updated.
      • posplayr
        • Jun 2015
        • 207
        I used PVwatts and did a quick run without optimization to compare a SE array 7K watt @152 Az and 43.7 Tilt to a SW array @225 and the same tilt 43.7.
        I downloaded the full years worth of hourly data into two separate spreadsheets so I could clip out only the Day Time savings data. Then I sorted by hour and plotted the data for the SE and SW arrays. I applied the primary rate schedule under TOU ($0.11 till 8 am, 8am<$0.30<2pm and then 2pm<$0.46<8pm). The main reason for clipping out the DST is I would have an 1 hour of shift between DAT and non DST data.
        I'm doing this is a spreadsheet so any more complex rules would be too unwieldy; I would need to pull this into a programming language.
        Bottom line, the SE panel peaked somewhere around 10:30AM STD (9:30AM DST) and the SW peaked around 1:00 PM STD (12:00(Noon) DST). The peak so early is owning to the solar roll off pattern more despite the shift in the "peak" to 2:00 PM.
        You can get some idea of time shift in harvest from early day to later afternoon. I did a quick numerical TOU average of the data and I got a 16% difference as summarized in the lower left hand comer. Obviously is is still a bit gross and well as un-optimized but it is probably indicative of the penalty the 152 degree az roof.
        Sensij, I'm not sure why you are not getting a bigger difference.
        EDIT: I noticed I screwed up and used 152 rather than 158 deg. It needs to be done anyway.
        EDIT 7/28/2015
        I refined the simple spreadsheet analysis to actually bin every hourly KW data point from PV watts for both a SE 158 degree 32.7 panel and a SW 248 degree 28 degree panel. Considering a static TOU for daylight savings of 0.11,0.30 and 0.46 with transitions at 8am, and 2pm as it is just simpler, and excluding the winter as it would require another spreadsheet.
        There are some interesting results. Fixed panels are usually optimum sometimes or to say it another way,most the year/day a fixed panel is almost always wrong. So being wrong less if the best you can hope for. However, it is clear that daily timing in favor of capturing higher TOU rates does offer some of the most fertile ground available for $ cost efficiency under Net Metering. Going through this exercise for the OP's situation bear this out.
        This comparison is only for Day Light Savings time which extends from Mar 8 to Nov 1. The comparison is to evaluate the feasibility of the SE roof v.s. the SW roof as a location for mounting panels. I assume the OP wants to use the SE facing roof for aesthetic reasons. The west facing roof is closer to the front of the house and much smaller. Regardless this is still a useful exercise. For the SE roof at 158 the tilt angle of 32.7 was selected as the optimum according to http://www.solarpaneltilt.com/.
        Sensij also ran some numbers showing that was in fact the best (based on Kw-Hr produced). The SW roof was selected obviously as it is much more west, lowering the tilt angle for the 248 az brings the normal back further to the east and also further emphasises the summer months so I did not lower the tilt any more. If fact if the OP so choose he would likely pick something for easy mounting. That portion of the roof appears to be much more shallow that the SE roof, so the roof slope would probably dictate the mounting angle as much as anything.
        In the figure above we see that the aggregate numbers for DLS show that although the (7Kwatt panels for both) SW panel generated about 5% less energy, it produced about 9% more revenue. The obvious time shift in the harvest, yielded less Kw-Hr but a higher Net Meter credit.
        SE SW
        Kwatt-Hr 8349 7960 95.3%
        $ 2389 2601 108.9%
        For me it reinforces the value of tracking, as the placement of a fixed array can only do so much even comparing such extremely different orientations. For the OP perhaps it offers an option to mount panels on the SW roof where it is cheaper to mount and 9% better economically in terms of NM credits. If you can't get all of the panels you want or need on the SW roof, placing the balance on the SE roof will capture more low angle solar energy and outperform the SW roof in winter. Being off of DLS will also tend to increase the value of that roof as well.
          The model shows a 7 kW array with a 248 deg az with 28 deg tilt could generate $2956 of credit annually under TOU-D-A, or ~10535 kWh under a straight tiered plan.
          The model shows a 7 kW array with a 158 deg az with 45 deg tilt could generate $2951 of credit annually under TOU-D-A, or ~11500 kWh under a straight tiered plan.
          Any suggestion that the OP install panels on a face other than the SSE face originally suggested is misguided, at best.
          Linked here is a spreadsheet showing the TOU analysis of the SW array. Perhaps some careful study will help explain the difference between these results and the incomplete, inaccurate analysis that suggested a different conclusion. Based on the little I can get out of what was posted, a fundamental misunderstanding of how daylight savings time works is responsible for at least part of the error, but with a basic mistake like that, really, anything is possible.
            FWIW, seems to make sense to me. I've found T.O.U time/rate structures to be pretty straight forward with a little effort.
            • posplayr
              • Jun 2015
              • 207
              I'm sure if the OP comes back he will be appreciative to Sensij for doing this analysis. He has used his detailed TOU-D-A model to confirmed that the OP has a viable "nearly" equivalent option in that he can obtain virtually the same annual credit using his Northwest roof plane with probably minimal angling utilizing an effectively flat mounting arrangement. I'm not sure if he was aware or if he had ever contemplated it? Of course it doesn't offer the same space of the SE roof, but then again the OP is having a hard time finding anyone to bid that SE roof. Which brings us back to the "near equivalence" caveat mentioned above. How much is it going to cost to mount panels on a roof when you can't get a bid to mount panels on that roof?
              We have heard that the 45 degree slope is probably the driver reducing any interest of OP's local installers. We also know that in large part due, to the 45 degree slope of the SE roof it is going to be more costly if not prohibitively do do any type of angling. In fact in a straight head to head comparison the mounting cost on the SW roof will be cheaper than the SE roof making the SW roof preferential purely looking a cost.
              Until the OP has a competitive bid in hand comparing the two, I would think you are in serious danger of prejudging the situation. While you see no issue with the roof, the local installer who have been offered a chance to bid have thought otherwise. We dont know why, but we do know there are other options.
              I know that if I was in the OP's shoes, I would want to understand the cost drivers of a bid are and what issues (if any) were driving it. The OP apparently has been pursuing exactly the path Sensji is suggesting and that is what lead him here. Whether "No Bids" or "High Bids" he is looking for answers and I would suspect options.
              Not to leave any stone unturned, let's get back to my prior analysis. The notion that TOU-D-A is a driver to annual credits is certainly valid. To use Sensji's numbers the SE panels at 45 degree flat mount developed (according to his model) $2951 annually while an optimized panel yielded would yield $3206 annually. While some might scoff, but when considering fixed solar installs even 8.6% gain is significant. Sure you can always throw more panels at the problems and solve orientation and mounting problems, but that assumes that you can find anybody to mount them (and at what cost). The issue I brought up was that the SE roof pointed east, and so was at a disadvantage for "afternoon harvest", the point being that other roofs would be better oriented and not suffer the same 8.6% loss. Is 8.6% significant, well yes. Is it prohibitive? No not so long as you know that you will under perform. The OP might just have his heart set on that SE roof just so he doesn't even have to see the panels from the front and he doesn't really care how many there are nor how much they cost.
              Is the 8.6% penalty enough to get a NO bid from your favorite installer? It doesn't seem like it unless the installer figures the OP will ask for some angling in the already difficult 45 degrees slope which would get back to a chicken and the egg questions is the the angle or the azimuth or is it some of both. Maybe the OP can do an exit interview and take a poll with all of his NO BID installers.
              In summary, the OP is looking for answers, doing the same thing is not working. He probably knows more now about his roof than he did before and he has another viable probably cheaper option (i.e. the SW roof). It was a good exercise for me as well. The decomposition of the PV watts data confirmed my suspicions, and now with a full model that Senseji has we have a full roll up to confirm the annualized results as well.
