  • SolarinOregon
    • Jul 2015
    Solar Inverters with electronics
    My Solar panel system is completely off grid. The inverter I chose is a 24vdc with an modified sine wave output. The system operates all my power tools and even my stereo amplifier. I was looking to use a solid state electric fence charger which is AC powered. I called the manufacturer, Zareba. The only response the rep could give me is to plug it into a standard outlet. Does anyone have experience running fence chargers on modified sine wave inverters?
    Try it and see if the unit heats up. A little warm is OK. really toasty hot is bad and you need pure sine for that device. Sorry.
      • 5204
      There are fencers that run directly from batteries. Some are more efficient than others. I would find one
      and use a rather small DC-DC converter to run it. Since the fencer may draw power in bursts, a super
      cap at its input terminals might allow a much smaller converter running continuously, instead of a large
      one capable of the surges, and idling at 0% efficiency between. Bruce Roe
      • SolarinOregon
        • Jul 2015
        It seams to work.
        I don't want to get a battery operated since I have my whole solar panel - battery storage - inverter working and supplying power to my outbuilding. All the DC units I saw required a 12 or 6 volt battery. My unit is 24volt and so not convenient to use a subset of my batteries. I purchased the AC unit and plugged it in. It is currently is working and does not get hot. I may have dodged a bullet. I was hoping that the modified sine wave inverter was close enough to a sine wave that the net effect would be that would function normally. So far so good.
          • 5204
          Fine if you run your inverter continuously. If you turn it off often to save battery charge, it won't serve your fencer. The
          scheme I proposed will and very efficiently, desirable for off grid. Bruce Roe
