I am looking to install a solar system on my home, 6kW in size. One of the first things I learned is that there are numerous and almost uncountable number of solar panel manufacturers. I have narrowed my choices down to these manufacturers: Trina, SolarWorld, Kyocera, and LG Solar. In all of these panels I am looking in the 300W per panel range. High efficiency is not the highest priority; I will be using only about 50% of my roof surface. Reliability and durability are more important than efficiency; I do not want to replace the panels every time a I see a hail stone fall out of the sky. Wind blows pretty often in my part of the country; the panel needs enough framework that it will not twist off of the racks. Normally, I would handle these questions by inspection of the panels myself; however, the closest DIY dealer I can find is 1000 miles away. So I am looking for advice.
Note that 6kW is all I can justifying purchasing in the state I live in (Oklahoma). Oklahoma has net metering so I can run the meter backwards when I generate more than I use. However, the power company does not have to buy electricity from me at the end of the month. So, in a nutshell, if my meter is negative at the end of the month it becomes the meter starting point for the next month. At least this is my understanding of how it works in Oklahoma.
Thank you for any advice in advance.
-RobBob
-RobBob
