I am looking at putting together a solar array using SolarWorld 285 watt panelsI would like to have an array with 18 panels total so I am in the 6000 watt range I am wondering if there is a solar charge controller for a 48 volt battery system that will handle that much wattage all of the Outback charge controllers that I can find are far short of that there is a company called Magnum that has a 100 - pt unit out there now but I can't find it for sale anywhere that theoretically would handle that much wattage as a single 100 amp unit. Does any one have any ideas on a charge controller that can handle 5130 plus 285 x 18 to 6000 watts.
Most Popular Topics
largest 48 volt charge controller?
Nope largest out there is Midnite Solar Classic Line Up and at 48 volts all they can input is 5000 watts. You are going to need 2 65 amp MPPT Controllers with 3000 watts of panels on each serving a common battery. No way around it that I know of.MSEE, PE -
Schneider Electric (xantrex) has a 600V 80A model
Midnight classic has 83A @ 48V http://www.midnitesolar.com/images/c...age/graphs.php
But I would split the array to 2 charge controllers, and let each loaf along at partial load.
I'd use 2 morningstar MPPT 60, and wire them to a router to monitor them over ethernet. Saves the cost of the optional graphics panel for each.
Midnight classics have ethernet remote control.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
At 6000 watts you are really beyond 48 volt battery capabilities. You have moved into 60 and 72 volt battery territory. Even 120 volt battery.MSEE, PEComment
I am looking at 16 6 v Trojan batteries two strings 800 (data sheets on my laptop) amp hours I don't have it in front of me right now.
So that I am not taking the chance of faulting out the largest charge controller mentioned above on a cold sunny day.
Right now we have been consuming less than 12 kw per day for the Last monthComment
Midnight classics have ethernet remote control.Comment
What is a concern is your battery selection. You do not want to use parallel strings unless necessary, and unless you want more than 4000 AH it is never necessary. If you need 800 AH then buy 800 AH cells. If 6 volt 800 AH cells are too heavy, get 2 or 4 volt cells. Secondly I am not sure what AH rating you are considering, sounds like 800 AH. A charge current of 130 amps ion 800 AH FLA batteries is a bit too much. ou need to keep it less than C/8 or 960 AH up to 1140 AH.
What size generator are you looking at?MSEE, PEComment
I think you are worried about nothing.
What size generator are you looking at?Comment
