I've been trying to understand how billing works for accounts with different TOU rates aggregated under NEM. Multiple calls to SCE proved to be an exercise in futility. This is a description of how billing works:
Say I have two accounts/meters A1 and A2, and solar is on A1. The solar system is sized for both accounts so that A1 will normally be a net producer. Does the above imply that in this scenario all energy that was exported to the grid in a particular billing period will be allocated to A2? Or does it mean the allocation will be based on the actual consumption as seen by the meter which is never 0 due to usage that exceeds solar output such as at night, so some generated energy will still be allocated to A1? Additionally it is not clear how credits are calculated for A2, is it done using A2's TOU rate in this example? I would think so.
My actual problem is that I need to decide whether or not it will be beneficial to aggregate my household and my EV charging meter under the NEM agreement. Yes ditching the EV meter and charging the car from my home meter would simplify things a lot, but I want to understand how aggregation works first before making the final decision.
Billing Methodology
SB 594 requires a proportional allocation billing methodology that must be computed
monthly. SCE will bill each metered service account participating in NEM
Aggregation individually, according to the billing provisions applicable to all NEM
customers. However, for accounts participating in NEM Aggregation (which will all
be placed on the same billing cycle), the energy consumption (kWh) registered on
each account’s meter will be reduced, for NEM billing purposes, by a proportional
allocation of the energy that is generated by the Renewable Electrical Generating
Facility and exported to SCE’s grid, as registered on the meter of the service
account directly interconnected to the Renewable Electrical Generating Facility. For
example, if the account directly interconnected to the Renewable Electrical
Generating Facility consumes 50 kWh, aggregated account #1 consumes 150 kWh,
and aggregated account #2 consumes 200 kWh (making the total consumption of
the NEM Aggregation arrangement 400 kWh) , the directly interconnected account is
allocated 12.5 percent (i.e., 50/400 kWh) of the energy exported to SCE’s grid by the
Renewable Electrical Generating Facility, aggregated account #1 receives 37.5
percent (i.e., 150/400 kWh), and aggregated account #2 receives 50 percent (i.e.,
200/400 kWh). SCE will require that the customer designate one account in the
NEM Aggregation arrangement to receive any remaining kWh not allocated due to
rounding after the proportional allocation described above is completed.
Since an NEM Aggregation arrangement (which consists of the account that is
directly interconnected to the Renewable Electrical Generating Facility and all
aggregated accounts) may include a mix of residential, commercial and/or
agricultural accounts, and, therefore, time-of-use (TOU), non-TOU and tiered rates,
all accounts in an NEM Aggregation arrangement will be metered at the 15-minute
interval level and the exported generation will be proportionally allocated in kWh at
the 15-minute interval level.
