SMA String VS Solar Edge with Power Optimizers
does 0-60 1.4 seconds faster than that T Bird, faster 1/4 mile, also gets 19 mpg, all on crap 87 unleaded. Yes I
compare cars to the 70s. Bruce Roe
Just to add to the fun-
How will the rapid shutdown requirement affect the SMA setup, down the road ?
My understanding is that the SE setup lends itself to implementing rapid shutdown while it will be very expensive to retrofit a SMA setup.
Will existing SMA setup's be grandfathered in and exempt from rapid shutdown ?Comment
SMA has a rapid shutdown solution which is costly and cumbersome to implement now but does not meet new automatic rapid shutdown requirements.
SMA did purchase Tigo which makes optimizers.
I suspect that they intend to use the Tigo IP to convert the SMA inverters to more of a SolarEdge type system. This will allow more integrated rapid shutdown (but not by just adding existing Tigo optimizers to an SMA inverter).
Last edited by ButchDeal; 05-04-2017, 01:32 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
