  • ExtremeAcres
    • May 2010
    I need 35W of constant power... how would YOU do it ?
    HI guy7s ...noob here... Look ...I know I cant come in here and have someone give me the majic formula to learn solar...
    I know I need to spend lots of time perusing and reading posts on this forum ... I'm a do it yourselfer ...and have been very successful with many cool projects. I know I have to do my homework.
    I've been fascinated with the idea of solar power for many years.... and now I have a true project that gives me a reason to dive in .
    I only found this site last nite...so I havent really read any substantial stuff yet ... and I know next to nothing ... but If Im gonna do a ton of reading to get a grasp on this subject...I might as well at least be targeting the direction of specifically what I need.
    I need to set up an off the grid system ...to power a 35W pond pump ...24 hours a day...
    what should I start reading about ... PV cells ?... inverter or converters ? ... batteries ? generally what amounts of each of these will I need ? so where should I start reading ...what would be GOOD keywords for me to gosearch at this site ? ("off the grid systems "...or more specific like "pond pumps" or DIY Builds ? )
    also the reason I ask for help in the right direction ...is Im still on dial up ...so navigating ANY website is extra slow for me ...so any shortcuts help me dramatically.... doing research on dial up is SO frikkin "last century"...
    thanks for any ideas as to the best place for me to start...
    Real easy and straight forward.
    Recommended Design Practice of Off Grid Solar PV Systems
    The design process is a fairly simple and straight forward that doesn
      Actually, if you have grid power, it's really hard to beat it for cost efficency. 10 cents KW for grind, about 70cents for solar.. So follow the scheme that sunking laid out, and you will know better, what the expense is. I can't improve on his verbage.
