We have a small 12V solar panels on the cabin that I am considering to expand. It consists of one 10W and one 30W panel in parallel, one 12 / 24V PWM regulator, and two 70ah lead acid batteries. Considering buying more/larger solar panels and a MPPT regulator that is more efficient. Is it beneficial to make it into a 24V system ? What is the benefits?
Consumption is low since it is a summer cottage that is not in use during the winter. The solarsystem has only been used for some 12V led light that hangs around in the cabin, and charging pc / mobile phones.
I've read that you can use smaller cable sizes at higher voltages with less power loss at 24V than at 12V. Can also have longer cables without equal power loss. Have read that one achieves faster charging on overcast with solar panels in series, because you achieves satisfactory charging voltage earlier. Are there other advantages to 24V ?
If the solarsystem becomes 24V I suppose I must run the existing 12V lighting via a 24-12 DC-DC converter. I assume the converter uses some power especially if it must be left on all the time?
I wonder therefore whether we should continue with 12V, or it pays to do it to 24V ?
