How will I fair with an 8kw system if I used about 11kw last year?
Most Popular Topics
8kw system with 11kw annual use
You would be way over producing annual demand in So-Cal...
Not sure with where you are.
sunny-hours-us-map.gif -
Do a bit of research and give something called PVWatts a try. Read the help/info screens first. Depending on tilt/a.If you are in, say Buffalo or Seattle, a 1st guess may be close to 11,000 kWh/yr. for an 8 kW system If you're in Albuquerque, an 8 kW system may well get closer to 14,000 kWh/yr. or so. It depends.Comment
For an 8 kW DC system in New Orleans - from PV Watts
RESULTS
3.27 660 65 4.59 829 81 5.03 983 97 5.71 1,051 103 6.02 1,127 111 5.98 1,059 104 5.80 1,066 105 5.49 1,016 100 5.17 924 91 5.16 982 96 4.18 794 78 3.54 706 69 5.00
11,197
$ 1,100
Requested Location new orleans Weather Data Source (TMY2) NEW ORLEANS, LOUISIANA 11 miLatitude 29.98° N Longitude 90.25° W DC System Size 8 kW Module Type Standard Array Type Fixed (open rack) Array Tilt 20° Array Azimuth 180° System Losses 14% Inverter Efficiency 96% DC to AC Size Ratio 1.1 Average Cost of Electricity Purchased
from Utility0.10 $/kWh Initial Cost 3.30 $/Wdc Cost of Electricity Generated by System 0.19 $/kWh [SIGPIC][/SIGPIC]Comment
