  • jd31
    • 51
    Thanks for the feedback guys. I too felt option # 2 posed water issues. And JPM brings up other good points about debris collecting under the panels, and not having the cement tiles for later use, etc. The company offered to take me to see other installs. Perhaps I'll take them up on the offer to see what the construction looks like. I'll try to snap some photos.
      I'm sure other installs look pretty much as you can imagine. What's to look at ? An array with a different roof under and skirting it. Option #2 is a pile of #2.
      • jd31
        • 51
        Mainly seeing the transition between the shingles and tile (assuming I could see a live install). The company is a roofing company so I'd expect them to know their stuff...but I'm also not finding a lot reviews of them online outside of Angie's list and Yelp.
        • ericf1
          • Oct 2014
          • 83
          There is a small subdivision down the street from me that has what you describe in option #2 on every house. I've never been on the roofs, so I can't say how they handled the drainage. In addition to the items mentioned above, I would also be concerned with a lack of air flow under the panels. Normally, you want your panels 4-6 inches above the roof. These installations are pretty much flush. Seems to me option 2 is form over function.
          24xLG300N+SE7600 [url]http://tiny.cc/n7ucvx[/url]
          • HX_Guy
            • 1002
            I also wanted to comment on air flow. Not sure what LG's specs are, but I know Canadian Solar requires that the panels are a certain amount off the roof surface, I believe at least 4".
              What I have been referring to are systems with arrays that have about 4" - 6" clearance between the roof deck and the array, not arrays that are flush to the roof with zero clearance.
              Zero clearance array to roof will decrease system performance over normal clearance installs by (in all probability) increasing the system temp. It will also limit accessibility to the underside of arrays for inspection/array servicing, etc, and so probably not a good way to go. However, the problems I mentioned with mixed roofing types are easier to avoid by careful flashing around the array.
              Overall, flush (zero clearance) arrays are not a good idea any more than composition shingles under an array and something else around it. Both ways of doing it will cause problems sooner than doing it for the long term.
              • SoCalsolar
                • Jun 2012
                • 331
                This method is 100% legit
                This method is 100% legit and not a steaming pile of #2 as some have suggested. Look around at the new homes that are built with solar integrated in the roof and they are largely flush mounted. Dead Animals getting stuck under your array causing your roof to leak? If this array was located Costa Rica perhaps because of jungle critters climbing the trees that sprouted because you lived in a rain forest. This is San Diego you could have an open hole in your roof most years and not get water damage because of the rain. Mold? Rotting flesh? a smell emanating from your roof? This thought experiment went way off the rails and yes somebody is peddling you a heap of steaming #2 but it isn't your solar guy. JPM you add a lot to the forum but I think your account has been hacked because that post was very short on evidence and uncharacteristically on high on hype. HOA's wising up on this scam? Evidence perhaps? Is your potential solar array visible from the ground or street? Why the talk of the flush mount?
                As far as the airflow when you remove tile and replace with comp you lower the profile of the roof because the comp is 2-4 inches thinner than S tile. If you combine this with a railless mounting system you won't affect the air flow as much as a railed system. While this method of mounting is legit the increase in cost is about 40% too much in my experience and that is why option number 1 seems to be a better value not because rotting flesh and fermenting guano will will stink up your neighborhood .
                  The only steaming pile of #2 here is your defense of a bad practice - you will see considerable loss due to increased panel temperatures.
                  • ericf1
                    • Oct 2014
                    • 83
                    Took a walk past some of these installations this morning and payed more attention. The arrays I saw were not actually co-planar to the roof. The top of the array is slightly recessed below the tile peaks while the bottom of the array is higher than the top, about 4" above the tiles. The mounting surface under the array is also not co-planar to the surrounding roof surface, and appears to drain onto the tops of the tiles below it. These are new construction homes that came with solar as a standard feature. They are 2 story homes, so it's difficult to see details from the street.
                    • silversaver
                      • Jul 2013
                      • 1390
                      Friend of mine had his 8kW solar flash mount on his new house with $$$ clay S tiles. They look really nice flash mount to the roof and the only concern I had is the cooling part. I know when these panels heat up, the performance will drop pretty bad. His solar is only been up on the roof about 3 months so I can't really tell if there's any performance drop since Winter/Spring. I have spoken with the installer about the cooling, he said the panels are actually about 3" above the roof. I guess time will tell... I'm just an messanger, so don't fire at me.
                        One usual PV design goal is to have the array operating as cool as possible. That goal of a cooler array is partially met and helped by air circulating on both surface of an array - top and bottom. Air circulation on both sides means the array must be stood off from the roof deck. Depending on roof type, tilt, and other things, about 6" or so seems to be a tradeoff distance that gets most of the temp. lowering benefit of the standoff while not becoming visually offensive. More than that helps a bit more, but the improvement is less noticeable for more distance.
                        Regardless of standoff height, if the sides of an array are skirted, air circulation will be inhibited. Less air circulation will increase the array temp., short circuiting the design goal of a lower array temp.
                        Without getting real technical, there are several empirical ways to est. performance penalty for flush mounts. Cheap/dirty trick: Use SAM, change the standoff height and notice the diff. in output.
                          You're a vendor ?
                          • silversaver
                            • Jul 2013
                            • 1390
                            I did SAM base on my system. It probably loss about 400kWh per year if mount less than 0.5". I guess 400kWh isn't much for people who prefer the look. My cross street neighbor install 2/3 of his 8.5kW on NE 65 deg just to avoid the street look.
                              What you describe is not what I'm writing about. I'm referring to arrays stood off a roof by 6" or so with the concrete/clay tile under the array removed and replaced with composition shingles under that array, while the original tile remains on the rest of the roof.
                              Such an arrangement can allow water and whatever is carried with it to flow under the remaining tile below the array through the open slit created at the shingle to tile interface. Lack of drainage from accumulated junk carried with the water and little air circulation will keep things wet and promote mold growth and rot. Not only does my engineering judgment tell me that, but common sense sort of screams the same thing.
                              My experience of having been a peddler prior to an engineering career also makes me skeptical of some vendors motives and their eagerness to engage in such shenanigans. Seen similar stuff and the often common attitude from the inside. My apologies to all the ethical, honest vendors whose job is only made more difficult by the scumbags.
                              That roofing system is not a good thing. About the only reason I can think of for doing such a thing is that it is easier and cheaper for the vendor. That benefit however, probably does not transmit to the customer via lower prices and any likely damage may go unseen and unknown until the unnecessary damage is done. Even with a price break, I'm not sure how I'd go about putting a value on increased probability of a built in rot problem.
                                400 kWh/yr. s probably as good a # as any. That AZ. probably cost more than that for an output penalty.
