Solar install turning out really bad - looking for some help/advice please.
How about the readers digest condensed version or cliff notesNABCEP certified Technical Sales Professional
Update on the system? It's doing great! It's produced 11.23MWh so far since install.
And some "feel good" info.
As for the new solar venture, that's doing great also. We've done over $1.2M in sales, sold 37 systems, have a team of 12 guys and looking to expand...so I guess in the end maybe the whole experience was a blessing in disguise.
Did the new venture do the install?
Inquiring minds want to know!NABCEP certified Technical Sales Professional
I've reccomended my vendor to a few people. I never say they will be the cheapest... I describe them as providing a good value..... with excellent workmanship.Comment
That's awesome! A real success story.Update on the system? It's doing great! It's produced 11.23MWh so far since install.
I (and I'm sure others) have learned a lot from your trials & tribulations, and have shown others that DIY is possible but not necessarily recommended. To that end, and with some of my own sweat equity, my project came in at about CDN$2.17/ watt. I procured all of the equipment on my own and hired a small solar start-up for the install. You helped me avoid a ton of mistakes, but more importantly, helped me ensure it was done right.
During installation, side view of our west facing "solar wall", this was a big challenge but it turned out great. The goal was having it appear as a row of 2nd floor windows:
Overhead view:
Thanks again!oilerlord's 9.23kW PlantComment
Wow, what a read...but seriously, thanks for sharing with us all! Glad it all worked out pretty well in the end...! Hopefully it keeps producing for you many, many years down the road.
(And, 80 pages? I just see 54 from where I sit now.)Comment
The racking appears to be Unirac and should have a proper stanchion made by Unirac for this racking system to avoid failure and warranty issues. I have attached a picture of what was used there, which is common for installing pool heating collectors and should be stainless. The flexible conduit should be metallic but which ever is used it cannot exceed 6 ft. in length by code. Just lazy not to use EMT there. Also note that it is unsafe and not code to use THHN THWN type of wire under an array without it being in conduit. And zip ties? really? where are the wire management clips? A sad but true fact is that the inspectors will not travel up on the roof anymore so obviously he plans on that strategy for passing the fire code setbacks. You should have a separate qualified contractor write up a report for the issues there, (one that will be willing to go to court with you). If this is California, Call up the CA CSLB and report everything to them first, they will guide you on proper legal procedure and start an investigation of the license being questioned. The building dept cannot help you, nor do they even care. If you were in my area, S.D. I would help you remove this person of their license through and with the CSLB because I see stuff like this all of the time and the contractor has usually has gone out of business when the incorrect installation becomes a failure. I did not read the whole thread before replying, probably should have. I just hate seeing this sort of stuff going on.As you guys probably saw in my other thread, my installer seemed to be pretty lazy/cutting corners from the start. It has only gotten much worse and now I'm in the thick of this and not really sure what my options are.
I'm not even sure if what he is doing is correct and or legal. A few things...
He is completely not following what we agreed on for the system design or what was approved on the permit.
We agreed on a layout that was mostly landscape panels in a particular arrangement, and he completely changed it without notice.
In changing this, he did not follow the fire setback code at all (which is 3' from the ridge, and that what is shown on the permit). There are spots where he left 0 setback and others where he left 2'.
He is not using the wire gauge specified on the permit, which calls for 4AWG. He is using 6AWG and 8AWG. Also not using the specified conduit thickness, which affect the fill and that was approved for a certain amount.
The permit calls for 6"x2"x2" posts for the racking with flashing and sealant. He used only lag bolts, directly through the tile and through the paper and caulked both with silicon, no flashing of any kind. The racks feels flimsy, they easily shake if you move them...can just lag bolts hold up hundreds of pounds of panels?
So now what I'm not sure. How he expects this to pass inspection I have no idea, especially the wire thickness which can easily be checked by an inspector or especially the fire setback.
This gallery has 1 photos.Comment
