At this point, I don't think the OP has many choices. No reputable contractor will want to take blames from someone else's mistake, if problem arises later, not to mention the possibility of getting dragged into the mud with contract litigation with the original contractor. For the OP, it's also an expensive alternative. If the OP can get the original contractor to follow the permit to the dot and watch it closely, there's very little risk. Most of the time, even the bad contractor knows how to do it properly but just lazy and want to cut corners and work less for the same money.
Most Popular Topics
Solar install turning out really bad - looking for some help/advice please.
It is always fun to read OP's thread. Poor people always have his sad reasons... no offense but great example for others who trying to acquire solar.
I don't think anyone can expect too much from a F rating installer with 1st experience on SolarEdge.
If you decided to work with original installer, try to find an experienced installer with Solaredge background to look up after the work for you. It will save you tons of time.
I.... have found a reputable installer with 2000+ solar job completed and 10 yrs in business (BBB A+ rating) still using hanger bolt as standoff. I have no choice but only can find a 3rd party to re-inspect their work since I believed it is ok.... No one is perfect, but we'll trying to get it right.Comment
Wow poor people, really? You do realize the cost of this system is on par with other installers right?Comment
I don't really mean moneywise poor..... maybe I should use the word unfortunate.
PS. I still don't think unfortunate is the right word. Because you are the one create this **** hole and still think you are smart. What else can I say? You never listen, cuteComment
How did I create it? Because I took a chance on a company that said they had some rough times in the past but all ways good now, and I personally talked to 5 of their past customers who seemed happy?
Whatever man, I don't see how that's relevant to all this now anyway. Enjoy your hanger bolt setup.Comment
Multiple unanswered complaints has landed a local general contractor an 'F' rating with the Better Business Bureau.
I agree, I might be screwed from an A+ installer with 2000+ job completed with ZERO complaint. I will not start bashing them until I got a clear result from inspection.Comment
Of course, but that is beyond the scope of the washer itself, which was what he was complaining about in this post. His concern was bonding the P400 piece to the rails (which I didn't realize initially). I pointed out there is a hole for a ground wire in the P400 piece, but it sounds like the homeowner is hoping grounding would be done via the rails to save some wire/labor.Comment
You can bond to the rails, and I think the star washer is OK. My system is done in that way, with #6 solid copper to each rail using a lay-in lug with a device that penetrates the oxide layer (a WEEB washer) and then the rails joints are bonded together with braided bonding jumpers, and the parts and panels are bonded to the rails with similar devices that penetrate the oxide layer in the aluminum. All of the parts are listed for the application and so satisfy the code (At least the parts I've read).Comment
I guess I can see why my installer cut every corner he did...this is very time consuming and tiring! Took me 4 hours to do 16 standoff posts (and I still have to cut the holes into the tiles)...oh and plus another 3 hours to undo all the work he did.
Oh and the comedy continues...anyone know a good way to find the studs in the roof? How about just drill till you find it??
For $9 he could have bought this magnetic stud finder! It works so well I was pretty amazed.
Nice pictures and nice work. You won't regret knowing that it will fully meet your standards.
Doesn't the stud finder work on the nails driven to hold the wood? If so it isn't any more
accurate than those nails. I have been known to drill a small hole where I think the edge
of a stud is, to see if I hit it, miss it, or run down its side. With that info I might even drill
another (small) hole to narrow it down more. I see some nails in the attic that missed the
stud. Bruce RoeComment
I don't see evidence your installer was there. Is he out of view of the camera?
This all looks quite a step above his work.Comment
