Hello,
I love reading everyone's experiences on this forum, I appreciate the knowledge! I've gotten a few quotes over the months and would love some feedback:
Here are some quick facts about my situation:
1. I'm on TOU-D-EV SCE rate because I own a Tesla S and charge Super Off Peak between 12am and 6am for about $0.10 a kWh. I run everything I can during that time (pool, fountain, laundry, electric toothbrush charging, etc.).
2. I believe, and correct me if I'm wrong it would be best for me to only offset peak, and off peak usage.
3. I live in SoCal and am with SCE.
3. My annual usage was 32,545. The breakdown was like this:
Peak: 3,940
Off-Peak: 15,500
Super-Offpeak: 13,105
4. I think a 15,000kWH generation should suffice because the credits that I would generate in Peak times would offset more than the rate at which I'm paying the Off-Peak rates.
5. I believe I need a 11.5KW system.
Here are the quotes that I received:
Local Contractor:
1. Seems to be a solid guy, is doing a neighbor's house in the area and they are happy with his work.
11.5KW solar system
47 245 Watt BenQ panels
47 Enphase 215 microinverters.
$33,350. ($2.9/KW)
Monitoring System a separate $750 (is this needed?)
SunRun
11.4KW
44 REC Solar REC260PE
SolarEdge Tech SE100000A-US inverter
$48,750 ($4.26/KW)
SolarCity
4.5/KW
Sungevity
3.98/KW
Thanks for helping me review. Let me know if you have any other thoughts.
Peak: 3,940
Off-Peak: 15,500
Local Contractor:
11.5KW solar system
$33,350. ($2.9/KW)
SunRun
11.4KW
$48,750 ($4.26/KW)
SolarCity
4.5/KW
Sungevity
3.98/KW
