Unfortunately not, there isn't the space, or the budget even if there was the space. It would be a lot easier to just go with more efficient/higher wattage panels like SunPower 345w anyway...but again it doesn't fit the budget.
Well, then if it was me, I'd go with the diagram labeled "final setup" and call it the day.
You've done your best with your sqft and budget,
Now grab a Mai-Tai and soak in the pool...
I can't believe that the installer would knowingly violate code.
Knowingly is the key; we install in three major metro areas, some with 15 or more different jurisdictions. A lot are still using the old fire code, and some that have changed over have very different interpretations of the new one. Also, sometimes there are questions as to which city a property is in, and occasionally one that crosses the city limits. All of these can combine to make it really hard to keep up with which rules apply on a given property.
Always make sure you tell the installer which city you're in, based on who you pay local property taxes to. If there's any doubt, your city secretary should be able to tell you exactly which code revision the city has adopted, and is almost always easier to get in touch with than the fire chief. If you're looking at an install that leaves, say, a 34" walkway instead of a 36" one, then call the chief and ask if you can get a written exemption. It's easier than a variance through P&Z, and most fire chiefs are expected to use common sense, which isn't always a requirement of P&Z folks.
