I did some research on tilt and it seems that optimal tilt changes throughout the year but I don't find it practical to manually adjust tilt. So, I plan to just set fixed tilt if my roof pitch is too flat. I plan to have most panels south facing but I have less south facing roof space so I may need to have more west facing panels. Regarding inverters, I was planning on micro-inverters. Would that make it easier to have panels facing different directions than string inverters you mentioned? Thanks.
Most Popular Topics
Newbie looking at solar install in Fremont, CA
Originally posted by solardreamerRegarding inverters, I was planning on micro-inverters. Would that make it
with micro-inverters. Bruce RoeComment
West facing strings, depending on local weather and shading conditions, may be almost as good as South facing strings. And for Grid Tie they have the advantage of more production during peak rate hours. Although TOU pricing is going through some major changes that reduce the payback on even West facing panels.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I did some research on tilt and it seems that optimal tilt changes throughout the year but I don't find it practical to manually adjust tilt. So, I plan to just set fixed tilt if my roof pitch is too flat. I plan to have most panels south facing but I have less south facing roof space so I may need to have more west facing panels. Regarding inverters, I was planning on micro-inverters. Would that make it easier to have panels facing different directions than string inverters you mentioned? Thanks.Comment
