Most Popular Topics
Sun hours
I'm of course looking forward to testing my panel snow gap theory. Generally the snow falls during
the night here, so I can be seen getting them cleaned off just before sunrise or whenever the
snow stops. Bruce RoeComment
Today was the first gap test, went pretty much as I expected. Snow was willing to drop intoOriginally posted by bcroeToday was the setup for another snow experiment. I have panels 2 high, meaning snow must
slide a long way to be cleared off 2 panels, and the pile of snow gets pretty big while clearing and
at the bottom. On one support of 6 panels I moved the upper panels 4" higher and the lower panels
2" lower for a 6" gap between them. Snow will only need to slide half as far, in half the quantity
before falling through the gap.
On the next support of 6 panels, I just moved the upper for a gap of 4". This winter will be the
test: does the gap work and how big should it be? Bruce Roe
a 6" gap (instead of sliding onto another panel). A little coaxing was needed to get it down
the 4" gap. I will probably go with 7" or 8" gap to make it easy in the future. I will need to
either turn some panels around, or use some short extension cords to cover the gap.
It was very nice not seeing snow on one panel NOT sliding down onto another panel.
Snow storm started 3 pm Fri, ended 2 pm Sat at about 10". That's different, the storm usually
ends by sunrise. Low light out there; the inverters didn't have enough power to start this
morning. However the near vertical panels facing E and W took just a tap and the snow fell off.
They made enough energy (3KWH) in the next hour, I can still say it has made some energy every
day. Need to work on a motorized tilt system. By sunset all panels were cleared. Bruce RoeComment
OK, everything is changed. First I had to find my password, did. The LAST button on the pages seems to be missing; need to go to the
bottom to at least see the number. If there is a NEXT THREAD button, I can't find it. Bruce RoeComment
Some things will have to be done differently in the new format. So far there are still ways to do almost everything that people want.
Notice that at the top of this page there is currently a "Page N of 8" display. That tells you that there are 8 pages, and if you type a page number into the first box you will be taken directly to that page.
In the list of pages at the bottom of the page the last page number of the thread is always the one directly displayed at the end of the list.
Next thread seems to be missing completely, but I never used it so I did not notice. Or do you just mean Next Page?
The arrow buttons after the Page N of M display will move you one page forward or backward. If you are at one end of the page list only one of the two arrows will be active.
If you are not already at the last page, there will be a Next button after the page list at the bottom.
Dave
P.S. If you post your comments and questions about the new software installation in the thread where Solar Pete announced the change they will be more likely to be seen and answered by staff.
Last edited by inetdog; 12-02-2015, 07:54 PM.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Thanks, I have no idea how to find that thread, or if I even saw it. Pictures on old posts seem intact. When I try
CAMERA, SELECT FROM PHOTO ALBUMS, get message
Error: You have no uploaded photos or albums to choose from
Bruce Roe
I think that there were some subtle changes in the database that kept some features from coming over. There is an Album feature that does not appear to be working, and downloading new images is intermittent.
Try posting comments and bugs in this thead: https://www.solarpaneltalk.com/forum...lar-panel-talkLast edited by inetdog; 12-03-2015, 07:08 AM.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
3 days ago we had a snow & sleet storm with a few inches of stuff. Its been too cold since toPv snow gap
test: does the gap work and how big should it be? Did it in the afternoon, had just enough sun
time left to make sure all were still working properly. Bruce Roe
remove the ice frozen on, but I went out to see what happened without my intervention. Groups
of 6 panels (2 portrait high) had snow slide down over 2 panels so that the upper panels were
60% covered and the lower panels were 100% covered. The lower panels were COMPLETELY
CLEAR where there was a gap. The upper panels had snow slide down into the gap. The upper
panels were about 40% snow covered above a 4" gap, and 25% covered above the 6" gap.
Results of manual snow clearing were good, but self cleaning were even better. By a year from
now, there will be a 6" gap for all 12 platforms. If I build any more platforms, panels will be landscape
(to reduce the distance for snow to slide off). I am wondering, why no one ahead of me has made
such a suggestion? I expect this won't work on a roof mount, as the gap would fill up instead of
dropping to the ground.
Next time we see the sun and above freezing temps, will see about getting the rest of the snow
off my south facing panels. Despite the gloom, my snow free near vertical east-west facing panels
managed to eek out 17KWH. Bruce RoeComment
My generation isn't much different this year. But the heat pump has helped reduce use in the fall. Now we
have had such warm weather (that means well above freezing in NW IL), energy use for warming the house
(to 74 deg) has been way down. At this rate my 2015/16 KWH reserve is way above previous. More like
12,600 KWH instead of 7000 last year. Perhaps I'll turn up the temp in the shop to use some up. Bruce RoeYou do not have permission to view this gallery.
This gallery has 1 photos.Comment
It is standard procedure in snow country to put panels in landscape orientation, but not for the reason you mention. Within most solar panels are several strings of cells in parallel. The strings run vertically if the panel is in portrait orientation and horizontally if the panel is in landscape orientation.
Snow slides down the panel and gets caught up on the lower frame of the panel. In portrait orientation, the snow blocks the lower part of each string of cells within the panel (no power). In landscape orientation, the snow entirely blocks just one string of cells and leaves the other parallel strings clear to make power.
Also popular in snow country are black-framed panels... they accumulate less snow than white or aluminum frames.
--mapmakerob 3524, FM60, ePanel, 4 L16, 4 x 235 watt panelsComment
My installer didn't seem to be aware of this "snow country" practice; in fact I haven't noticed ANY panels
--mapmaker
mounted landscape here. Maybe that will change. If I lost the bottom row of cells in many panels, I think
the whole string would drop out. It would be dominated by the parallel strings with no blockage, at full voltage.
Bruce RoeComment
It was a little late, but eventually the sun come out on one of the shortest days of the year and made me 70 KWH. Bruce RoeComment
Looks like dreary Dec is past, getting more more sunny days where production reaches half the summer peak.
1/2" snow came at night; I looked at the gloom and said "is it worth cleaning them?". A little later though the sun
started showing, so I went out and cleaned them up. The inverters immediately showed 12 KW. Once the sun
cleared all shading, they maxed out at 15KW whenever no cloud was blocking. Its often too cold for the heat
pump, but I'm trying to keep enough resistance heat on so that the furnace doesn't run. Bruce RoeComment
Any recommendations for when it DOESNT naturally slide off? My installer said the same thing, not to worry about it and that gravity will take care of this as my roof is well pitched. Reality is that half of my array cleaned itself, the other is completely covered in snow and has a huge snow/ice dam at the bottom that will prevent anything from sliding off. Both halves of my total array are identical and face the same direction with same roof pitch. Unclear why one side is fine, the other is a disaster.
Looking for ideas how to fix this mess. It's a colonial house so the roof is high up and I can't get a ladder up there this time of year with all the snow. Hesitant to use a roof rake for fear of damaging the panels.Comment
