  • snic
    • Apr 2012
    • 73
    Originally posted by peakbagger
    I find that if I can get the lower portion of my panels cleaned off, that when the sun come out the rest of the array melts fairly quickly. What seems to slow things down is when the snow is built up at the base of the panels as the snow tends to slide down in sheets and get stuck. If I clean off out front and on the lower panels, the sheets tend to accelerate and keep going.
    Hm, that's interesting. But for my house I'd need the $150 rake just to get the lower part of the lower panels and no more. Not sure it's worth it. I live in NY (near NYC), and although it certainly does snow (and this year especially), I think it would take quite a few snow storms to recoup that investment - even if I could get all the snow off, not just the bottom one eighth.
    Originally posted by WillBkool
    I'm an hour east of Pensacola and my panels were covered with snow/ice from late Tuesday until about 10 am today. I never thought that it would happen in Florida. Could I use room temperature water to remove the snow/ice from my panels like I had to do with my car? Even the doors were iced shut!
    If it involves climbing on a ladder, don't do it. Especially if everything is covered in ice.
    • itnetpro
      • Oct 2013
      • 49
      Yea I admit it could have been a waste to spend $150 on a 30ft poll but I wanted it anyway. Thats what happens when U already own everything you want. You get bored and buy stuff like this that might not really be worth it. I could have gone with the $75 25ft poll. That would have been more then enough to clear the panels on my garage but no that was just not good enough for me. We don't have kids so need something to spend our money on...
      John
        • 15169
        John
        Do you make zero interest loans?
        By the way when I use the Italic font I am usually just kidding.
          [You should have done this!]
          I am still proselytizing for use of the Comic Sans MS font for that purpose instead of just italics. Less ambiguous. Of course I have not been able to persuade anyone (except possibly Naptown) to follow suit.
          Italics are ambiguous. Comic Sans forever!
          You will notice, among other things, that when your post gets quoted, the whole thing becomes italics and the distinctiveness is lost.
            • 15169
            Another good point. I have been "learned" twice today by you.
            • itnetpro
              • Oct 2013
              • 49
              Five to eight inches of snow coming our way tomorrow. Looks like I'm gonna get an opportunity to try out my new 30' snow pole. I work from home so I will quit work 30 minutes early around 5PM while I still have a little daylight left and give it a try.
              John
                John
                Maybe a short video clip showing when you pull the snow down on top of you or similar would be possible?
                • snic
                  • Apr 2012
                  • 73
                  Yeah, I want to see this too! The internet needs a few good videos of solar panel snow removal, especially if they involve personal avalanches.
                  • peakbagger
                    • Jun 2010
                    • 1566
                    Anyone in northern NH is used to the snow avalanche when raking a roof. I have removed 26 inches of snow (one storm) off my roof and I usually don full winter gear including a balaclava. When the stuff falls down off the roof it turns into heavy dense snow. Folks with steep pitched metal roofs have to be real careful as folks have been injured and killed as it usually all comes down at once while asphalt roofs have to b raked down. Most of the metal roofs are now equipped with snow hooks to limit the avalanches or at least break them up a bit.
                    • itnetpro
                      • Oct 2013
                      • 49
                      Jeez, thats more information then I ever wanted to know. All I wana do it extend the poll, lay the little rubber thing on my roof and pull. I think the slope on my roof is sufficient where I will avoid the avalanche and live.
                      Something tells me I should give this project more time then the 15 minutes I allocated before the sun goes down tomorrow.
                      John
                        Please do keep in mind the video - just in case!
                        • itnetpro
                          • Oct 2013
                          • 49
                          Nine inches heavy wet snow fell in my neighborhood. Garage roof was easy peezy. Was able to clear all 12 within minutes. 12 panels 250w (225w clipped) each should generate max 2,700w of my total 10k system so I'm happy. As for the main roof, the 30' pole does reach up there and I can remove the snow that packs at the bottom of the roof over the gutter. With that removed the roof should clear sooner then normal. With some work I might have been able to clear the first panels up there. Only issue was pole is bit to flimsy fully extended and thats just more work then expected.
                          Oh well, yea I could have been happy with the 25ft pole at half the price so bigger is not always better but then again you never know when I might need that extra 5'.
                          John
                          • Naptown
                            • 6880
                            [QUOTE=itnetpro;98026 bigger is not always better but then again you never know when I might need that extra
                            John[/QUOTE]
                            Depends on what business you are in
                              I get a few emails almost everyday claiming bigger is better!
                              • snic
                                • Apr 2012
                                • 73
                                Yes, but nothing beats "9 inches of heavy wet snow." Especially when it's being beaten by a 30 foot pole. You don't need e-mail for that kind of imagery; you just need a guy with some solar panels! And white-out conditions, of course.
                                (Come to think of it, maybe it's a good thing the OP didn't post a video...)
