A search hasn't returned what I am looking for so I hope I can find the guidance that I seek, please.
My grid-connected domestic roof mounted system in the UK Midlands has sixteen Hyundai HiS-S245MG Silver Monosilicon panels connected as two strings of eight panels to a Sunnyboy SMA SB 3800V inverter. Installation was in early December 2011 with a Sunnybeam bluetooth data logging module added about six months later. I have a full set of generation and log files since that point. From day one of the logging module being installed I gave up trying to get the hopeless installer (long story) to fix a repeated "Insulation Failure" - though until what I describe below the system has generated about 5% ahead of my expected payback curve. It has never tripped or gone off line other than to prevent islanding during two grid failures. Other than the nag of the error message and wiring under the panels looking like a bowl of spaghetti, I've been happy.
Background:
Investigation:
What followed:
Question:
Before I start calling PV installers to ask for the fault to be traced and fixed (and probably paying for scaffolding too) what are the likely causes of the problem from the evidence I have provided and are there any other tests I can perform myself. The system is not currently reporting any faults despite the fact that one string is obviously poorly. The last time "insulation failure" appeared in the Sunnybeam log was a week ago so it may be a red herring.
Many thanks for your help.
Background:
- A few days ago I noticed that my PV system’s production was lower than expected even for the time of year
- No errors in system log file
- Checked with village friend (identical system on identical house with almost identical orientation, installed the week after mine) and found that his production is twice mine
- Suspected failed string
- I then compared my generation logs (10 minute granularity) with my friend's
- Failure happened on 22nd December at the height of a gale (confirmed by historical met data on line)
Investigation:
- Isolated AC, Isolated one DC string at breaker, reinstated AC
- Production stayed the same
- Isolated AC, Isolated the second DC string at breaker, reinstated the first DC breaker, reinstated AC
- Production fell to zero
- Isolated AC, Isolated both DC strings at their breakers, removed safety covers from breakers
- Measured input voltage of each on a grey day just before rain and with the "sun" at an oblique angle
- Suspect string: 32v DC
- Other string: 297v DC - pretty much as expected according to how I read the tech spec for the panels
What followed:
- I found that my installer has ceased trading
- Insurance Backed Guarantee won't pay for investigation or rectification until the Installer is wound up at Companies House - in process but not completed yet and no idea of timeline
- Meanwhile I am losing generation - though thankfully in the low point of the year
Question:
