For those of you that decided to buy your own equipment directly from a wholesaler then find someone to install your solar system, what did you guys pay? I reached out to local company and was quoted $1.25 - $1.50 / watt which seems very high for a 17kw job. After going back and forth they dropped the price to 85 cent / watt pending a home inspection. They also advised if they provided a turnkey system they would be in the $3.35 - $3.50 range.
What I am trying to determine is the vale proposition of buying a system turnkey vs. buying materials myself and hiring someone to do just the install. I certainly don't debrudge someone trying to make a living but I like to know what I am paying for. As best as I have able to to determine, here are the major costs components to an install:
Panels - Obviously a range here, but if you exclude Sunpower and higher rated panels, you can get prices in the 85 cents to $1.05 for poly/mono's in the 250-260 watt range
Inverters - String (30-40 cents / watt), Solar Edge (45-50 cents / watt) and Micros (60 cents / watt)
Racking - 30 cents /watt
So for a decent 260w mono panel + Solar Edge + Racking = $1.80 / watt. Then I understand there are fixed costs like permits, interconnection, monitoring, etc. And then to run any succcessful business you need to make enough profit to cover overhead, marketing, warranty reserve + still earn a decent living. I get it.
So, fellow homeowners, what kind of deal have you guys been able to get on install only jobs? $/w basis or hourly rates or day rates, etc.
Thanks
Thanks
