Based on the California Energy Commission report (http://www.gosolarcalifornia.ca.gov/...pv_modules.php) of real world test, at the same watt rating, the poly version of the panels by the same maker best the mono version each and every time. This seems to contradict the conventional wisdom that mono is more efficient. Furthermore, poly panels are better in low light supposedly and cheaper to produce. Is there a reason to pick mono panels?
I now have two homes (one with 5.04kw Trina SMA combo and one 5kw Canadian Enphase combo). Both are free from shades. I will compare the performance tonight after sundown to see if the enphase's supposedly better production in low light will allow it to eek out any performance gains over the SMA.
As a bench mark, the 5.04kw system for the past few days has averaged 31.5kwhr production a day.
