Hybrid invertor that can priorize supplying load from solar without using batteries?
  • JunglaSol
    • Mar 2024
    • 3
    I have a solar backup system - 1.2kw of panels, 4 lead carbon 150 vah batteries, and a cheap chinese invertor. The invertor _can_ prioritize "renewables" over grid, but it doesn't distinguish between solar and batteries in this mode, so that means that it decharges the batteries every night, which then recharge from the grid. This isn't ideal, because a) it means that if we have a grid outage (which is common where we live) that our backup capacity is much reduced and b) the constant cycling on the batteries obviously impacts their lifetime.
    I would like to replace the invertor, and am looking for recommendations. My requriement is that it should be able to be programmed to follow two rules:
    1) solar power should go to charging batteries if needed; otherwise it should contribute to the house load;
    2) grid should be used in priority over batteries; i.e. if grid goes down, we want to draw from solar + batteries, but if solar is not producing and grid is up, we want to use grid
    We would save approximately $100/mo with it running like this, and ideally am looking to keep pay-back under 3 years, so ideal budget is $3500 and under.
    Thanks!
    I am not sure if that equipment is available yet. But I am unsure why you don't have a generator to recharge the batteries if the grid is down. Most people that have batteries also have a way of charging them if the grid is down and it is cloudy out so the panels don't produce enough power.
    • JunglaSol
      • Mar 2024
      • 3
      We have reliable sun every day in our location, so no need for a generator. However, that doesn't work at night. (That said, the batteries at 90% capacity are plenty to keep us powered overnight until dawn.)
        I understand your position. But everyone that I have talked to that has batteries also has a gen set of some kind for the long periods of clouds
        • JunglaSol
          • Mar 2024
          • 3
          Our system's been working fine for a year fyi - and we've had 18 hour outages and been fine. This is just an upgrade we are looking for, since we're effectively losing the energy from 8 hours of production per day.
          I know there _are_ invertors out there that do this - e.g. some by Sol-Ark. But hopefully other forum members have ideas.
