One or two PVs for multiple houses / structures?
  • cdreke
    • Dec 2023
    What would be the pros/cons for wiring a shop, and possible two houses on the same lot to the same PV (grid tied) system?
    Would it be better for each to have its own or one larger one?
    The power company electrical is 150' away from the shop (it has room for a lot of panels). The house is a further 500' away from the shop and an ADU is nearby.
    I am thinking of building a little power-shed near the house, connect the solar panels from both the shop (longer distance) and house to the power equipment in the power shed, and then run sub-panels to each of the 3 structures (shop, house, ADU). Does anyone see any downsides to this approach? Is there an advantage to having the shop have a separate PV and the house have its own PV?
    Thanks in advance for any input!
    Chris
  • BryceFreeman
    • Nov 2023
    • 16
    I would say seperate PV will be easier for troubleshooting and maintenance. If you got one PV for 2 or more houses and they are far away from each other, when some parts of the system are faulty, for example, it will take you a lot of time to check them from one place to another.
      • 5208
      I would expect you would figure the needs of each building and
      then see how the Solar output would feed to the grid with net
      metering. I use direct burial cable to connect it all. Because the
      solar runs continuous high power for many hours a day, that run
      might be calculated to hold down IR losses to around 2%. Other
      buildings might tolerate more peak loss, rarely attained. Some
      of my postings here show how 4/0 aluminum triplex (equals 2/0
      copper at 1/5 the price) was used to do this over distance.
      A ground mount panel array has many advantages, I have a list of
      52 reasons. Location for best sun (least shading) might be the first
      consideration, then minimize wiring losses. A series arrangement
      of panels will operate at maximum voltage, minimizing losses and
      wire required compared to a micro converter setup, and is cheaper.
      Check regulations too, less on a ground mount.
      good luck, Bruce Roe
      • cdreke
        • Dec 2023
        Thank you! The place these are going (HI) unfortunately does not have net metering anymore. It was supposedly phased out for new customers. Might come back at some point. As far as mounting, ground mount sounds pretty good. One of the building does have a standing seam roof but I am looking at a carport like ground mount that might work even better.
