Thoughts on this quote
    While I whole heartedly agree with the sentiment expressed and suspect in areas with recent and ongoing power outages that as more folks get ICE generators, HOA's will be faced with defacto CC & R changes that result in after the fact rule changes.
    Still, at this time the percentage of homes with standby ICE generators is still quite small, although I suspect that percentage is larger in HOA communities than in the general population - mostly due to the monkey see, monkey do/keep up with the Jones attitude more common in HOA's as well as more affluence.
    FWIW, and this is little more than anecdotal, I belong to 3 HOA's in So. CA, none of them in fire prone areas. At this time, none of the 3 make any mention, direct or indirect, of on site power generation using ICE's either for or against. While they all have rules covering excess noise and quiet enjoyment, there is no mention in any of those 3 sets of CC & R's of/or any rules covering noise emitted by stationary generators.
    CC & R's partially respond to general trends, usually as a reaction to when new things and trends disturb the perceived status quo rather than being proactive about how things are changing.
    As for changing the rules, small numbers of folks will have little chance against social inertia. When a convenience is changed to a necessity by common perception or brainwashing, the CC & R's in effect get reduced to an afterthought or less. CC & R changes then follow.
    I know that when I lived in an HOA community the rules stated all satellite dishes could not be in the front yard but at the time it was written they were 6 feet in diameter. Another rule was the material of the mail box and since the rule was written plastic had become the norm for new mail boxes which violated the rule. And finally the rules stated roofs had to be shingle or tile. But someone put in a metal roof which was a better option for insurance. People complained but had nothing to stand on. So we rewrote the rules to meet the latest products.
    My guess is that with more and more power outages a generator will become standard in new builds and a whole house generator will be quieter then a portable one. So HOA will need to change the rules or get hit with lawsuits.
      What you write makes perfect sense to me and I agree.
      Full Stop.
      However, my experience is that HOA CC & R's are usually or at least often only slightly less difficult to amend as the Constitution of the United States.
      Hell, in CA it took the state legislature to write legislation that dealt specifically with HOA's and residential PV and that only became law because the solar industry had a stronger lobby and a lot more popular support than HOAs. And it was still pretty watered down and vague with wiggle room for HOAs.
      HOA's are generally pretty entrenched in the status quo. When, in conversations about such things when people bitch about their HOA, I remark that HOA residents think CC &R's are usually great for everyone but them, and offer the idea that no one had a gun to anyone's head to buy into an HOA.
      The bottom line is HOA's are not hotbeds of change. Those in HOA's have, in reality, often have fewer realistic prospects to change things than those not living in HOAs. But they were advised of that before they bought in. Caveat emptor. To counter that somewhat, the perception (at least) among many residents is that there will be less unpredictability in neighborhoods and less disruption - and often, in a case of "the rules applying to everyone but me", a lot of unrealistic expectations about what neighbors can't do and what an individual member can do.
      • Just Steve
        • Mar 2022
        • 20
        You can do the same with PVWatts. It just takes 2 runs. Use the hourly output option and sum the parameters.
        I've been using SAM as a registered user since its original issue. It's useful and powerful if you know what it's doing and the concepts involved. I certainly and strongly encourage anyone to use any tools available to them. But without a decent engineering background to understand what SAM's asking for and what it's outputting, SAM is pretty much useless, or less so.
        Maybe Just Steve has such a background, but from what he writes, it doesn't sound like it.
        While I'm big on learning as much as possible about solar energy, if Just Steve is like most folks I've helped or attempted to help to get up to speed with SAM (most of who usually and quickly walk away from it when they see what's required), my guess is it'll take him longer to get proficient enough (and he certainly can if he so chooses) to understand how to get all the inputs right and so get meaningful output than it will to simply do two PVWatts runs, use the hourly output and sum the results.
        From what he's described as what he's looking for so far, IMO, at this time Just Steve will get more of what he needs out of the Dummies book than a deep dive into solar engineering and its finer points.
        An analogy: You don't need a degree in combustion engineering to tune up the internal combustion engine in your vehicle.
        BTW, SAM isn't an upgrade to PVWatts. They share some data bases for inputs but they are use different algorithms, are different in purpose and have different genealogy. The modeled results for each will be similar but probably slightly different for the same application. SAM was birthed by NREL. PVWatts genetic heritage came from Sandia labs. Another difference: PV modeling is almost a side show for SAM. It does many other types of modeling applications than simply PV.
        Mike 134, thanks for the link.
        JPM you are correct SAM is a tad over my head and have no desire to kill as many brain cells required to learn how to use it. I am also in the middle of the "Dummies" book, interesting.
          I'm not sure correct or over your head are the most apt descriptions. Since I'm of the opinion that most folks are, within some small measure about equally capable of understanding anything they set their minds to, my guess is that SAM isn't beyond your capabilities as much as beyond where your interests lie or the depth of knowledge you need for the task at hand. Anyhow, the Dummies book is a good primer. Besides, there's a lot to wring out of PVWatts - probably as much or more than you need at this time. If you're still curious, it's also a bit of a primer for more detailed but no more complicated stuff like where SAM and other algorithms will take you. One of the nice things about a brain is if you keep it active it never stops being curious.
          Hollar back with any questions.
          Good Luck,
          J.P.M.
          • nomadh
            • 230
            Good, then keep your investments healthy and rethink the whole solar/battery thing. Begin by getting more informed. Get a book: "Solar Power Your home for Dummies". ~ 25 buck +/- some at amazon/bookstores and disabuse yourself of the peddler hype and that of their media shills, or friends/neighbors who probably know less than you about the subject.
            As others seem to suggest, consider skiping the batteries. You can buy a lot of propane and the equipment to burn it as well as a lot of help to run that equipment once in a while for a lot less than the $20+K an overpriced battery bank will cost.
            Make arrangements for help during power interruptions and get a propane fired generator. Better, cheaper, more practical during power outages. Also, unless you plan on some effective method to remove snow from the arrays, plan for some reduced winter production from snow accumulations on the panels. That's one of the things solar peddlers either ignore or soft peddle.
            Also, unless you have a lot of shade, and in spite of what the solar peddlers may tell you for reasons they aren't usually willing to share with their marks, I'd skip the micros as they violate the KISS principle big time - a lot of duplicate electronics that are sensitive to heat, cold and the elements in a harsh, exposed environment that's about as hot, cold and inaccessible as any in/on your home.
            If cost effectiveness has any place in your consideration(s) to get PV, if you have so much shade such that micros are mandated (which is about the only semi logical reason for complicating things with micros), that calls into question the financial sense PV makes in the first place because less sun == less electricity production == less bang for the solar buck.
            Welcome to the neighborhood.
            You know the funny thing here is on my guitar forums almost never do the other members try and tell the new guy to NOT buy the guitar they are talking about.
            • Mike 134
              • Jan 2022
              • 432
              I would tell you to hold off on a Martin if you were just starting out.
                Why do you think that is ? Just curious.
                  Forums have unique cultures. Some are more critical than others. Some are more helpful than others. Visit several solar forums and you will see the variety of information available.
                  • sdold
                    • Jun 2014
                    • 1452
                    The difference with solar is that the results of a poor buying decision can be financially painful or even devastating.
                    • DanS26
                      • Dec 2011
                      • 987
                      Steve...if you do go the backup pad mounted generator route, just be aware that the generator salesmen are just as slick and slippery as the solar salesmen.
                      It is their job to over sell....that is recommending in most cases a machine that is way oversized for your needs. Get to know your loads before you buy, or better yet know the loads you can and can't do without in an outage. Do you really need a machine to power all the loads in your house or can you survive with maybe only 10 critical load circuits. It will make a big difference in initial costs and ongoing running costs.
                      • Just Steve
                        • Mar 2022
                        • 20
                        Good tips thanks.
                          I agree. A smaller generator will also reduce your fuel consumption and save money.
                            Yes that is most definitely the downside. On the upside a properly designed system in the right rate environment can provide a financial return by reducing costs. Because there is a broader spectrum of outcomes one has to use good analysis tools to make sure the optimum results are achieved. Also because the technical jargon is difficult for some to understand, there are more opportunities for unscrupulous sales people to oversell.
                            • Just Steve
                              • Mar 2022
                              • 20
                              Ok so I received some revised quotes without the battery storage but still using micro inverters because all of the companies I speak with thats all they use, that been said please see the attached and tell me what you think.
                              Thanks
                              • Mike 134
                                • Jan 2022
                                • 432
                                You're at $2.98 a watt before credits $1.53 with all credits. They work on commission. Everything is negotiable. I'd respond I'd hoped for $1.00 watt after all rebates and credits. Maybe you'll get a few more dollars off maybe you won't. Doesn't hurt to ask.
