I have a 5th wheel trailer,I'm trying to go off grid with this but my snag is.i have a 120v transformer feeding power to caravan.my inverter is a 4000w/8000w pure sine wave.having the transformer on this will it effect either the inverter or transformer
120v transformer onto a power inverter
Inverters often have a hard time when first connected to a transformer and they can overload until the core of the transformer gets magnetized. What is the transformer rated for ? The 4kw inverter should be able to power up a medium size transformerPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
a 4kw inverter should be able to manage a 1kva transformerPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
