I have the inverter ordered! and my panels and other equipment on the way.
I had asked the sales engineer at Renvu to look over my system as they helped me with the design. I noticed that the skybox voltage range says 200-600v. I ordered 14-380watt panels after discussion with the engineer. That would put me slightly above the 5kw rating at max output. He said this is fine and common to be slightly over at max.
However, something in the skybox quick start guide has me concerned. It says the skybox will connect to the PV array if the voltage is above 250 vdc. if I use 2 strings of 7 48v panels, I may drop below 250v at max output according to my Solar Design Tool project I put together. It says I may be at 237 vdc at max temperature (range is 237-386) using two strings of 7 panels. So I initially thought I'd be ok with the skybox specs saying 200-600v, except on that quick setup guide where is says 250vdc to connect..
Will I run into any issues with this setup?
Thanks!
Thanks!
