You appear to be on TOU-C which has a baseline allowance. The only way to tell if that is better than TOU-C is to estimate how close you will come to that allowance. So far no one here has offered any experience with programming a Solaredge inverter with LG Chem batteries. All I can presume is that the inverter is a Storedge model and that the programming is done with the inverter interface.
I have no experience with that model but if you don't have the manual, it can be downloaded. At least that would give you a sense for how it can be programmed. Then you could quote parts of the manual to tell them how to do it. Also a few well crafted searches on the Internet may give you a better way to approach Vivent for access to programming the inverter to optimize what you are paying for. They are part of Sunrun now.
