NorCal, Tesla 4kw + 1 powerwall
As a certified Tesla installer who has designed numerous Powerwall systems I would suggest that you request your installer use a Gateway 2. This Gateway has a 12 slot internal panelboard option that can hold 3 full size 2 pole breakers or 6 Eaton Quad breakers. It can be configured to be either a unbacked up heavy load panel or an essential load panel.
Andy
What are your thoughts on going with a 4kw Tesla system (12 panels) with a powerwall, where other vendors are generally sizing me at 5.5kw and about 16 panels? The jump with Tesla from 4 to 8 kw seems huge/overkill. But I dunno...Leave a comment:
Agree. Im trying to pick up as much info as I can!Leave a comment:
As a suggestion, don't ask a question of a vendor that you don't already know the answer to. You'll learn a lot more about PV that way and almost as important, how many vendors don't know as much as you will and usually B.S. the solar ignorant.Leave a comment:
Andy
Thanks Richard and JPM! Good questions for me to ask the vendors, max system production vs. Avg expected system production...Leave a comment:
Getting back to the original discussion about a 4kW solar installation with one PowerWall in northern California, I would caution the OP to not base the analysis on a theoretical best day performance of 30kWh. Based on my 16 months of history with a 4kW system in Poway, CA, I have yet to see a single day produce 30kWh. The best single day I've seen just barely touched 29kWh of solar production. Down here in Poway, the best months I've experience are averaging 26kWh/day while in the worst month I couldn't even produce 14kWh/day. For my first full year, I've averaged 20.4kWh/day. If the back of the envelope economic analysis is built on a 30kWh/day production I suspect the OP will be sorely disappointed in his actual performance. I also doubt that he will have enough excess solar to keep a PowerWall charged during anticipated times of power shutdowns.
Of course I could be wrong....
FWIW:
my zip: 92026
System size: 5.232 kW.
P.T.O. date: 10/17/2013
Array orientation: 195.75 deg. azimuth, 18.75 deg. tilt.
System has ~ 3.5 % total production penalty from tree shade that occurs daily from ~ 1530 hrs. onward.
Total system production since startup: 61,068 kWh. No dropouts, no downtime. That total is from the system monitor but adjusted downward by 0.0051% to account for disparity between monitor and SDG & E meter.
Approx. max. possible system production including shading loss since startup with same weather but with/if 100 % clear skies every day: 75,495 kWh.
Average running 365 day total annual production after 1 year of operation: 9,068 kWh/365 days, minimum, 8,716 kWh/yr., max. 9,571 kWh/yr., population std. dev. : 191 kWh.
Average system daily production: 24.81 kWh/day. Maximum: 35.47 kWh/day. Minimum: 0.66 kWh/day, population std. dev. : 7.80 kWh/day.
Average system daily production per installed STC kW : 24.81kWh/day/5.232 kW = 4.74 kWh/(day*installed STC kW).
I estimate system production degradation at roughly 0.30 %/yr. to maybe 0.40 %/yr. Published from data sheet says 0.40 %/yr.
I'd expect Richard's system to do a bit better/STC W than mine at least partially due to it being in service for a shorter time.
All that is to agree with Richard's statement about analyses based on best (and so non typical) production and some possible example/info on why it may not be a good idea to not plan things on optimum production numbers.
Take want you want of the above. Scrap the restLeave a comment:
Of course I could be wrong....Leave a comment:
I had an appraisal done on my home after I installed solar and the appraiser added 50% of the cost of the solar to the value. The only questions he asked were, do you own it and when did you install it.Leave a comment:
I'd like to see the numbers behind the numbers on that info from Zillow.
Believe it or not, and for various reasons, not all folks who might want to buy a home are interested in PV. Maybe I'm wrong here, but seems to me that would reduce the size of the pool of potential buyers. If so, and if supply/demand still works, that probably won't help increase the price.
Not that it matters, but I wouldn't consider any home w/ existing PV on it, particularly a system that's, say, 10 years old, and additionally, not sized to my load. Suppose the system only generates $10K in offset revenue ? How many prospective buyers even know their annual usage much less how how to determine an existing system's output.
The way system prices are coming down, if I was interested in a property and it had a PV system on it, even if I was positively inclined toward the system, I'd use it as a bargaining point and say something like: I like your home, but not the PV. Besides, I can get a new system sized to my needs for less. Here's the deal: I'll buy your lovely home if your either remove the system and make the roof whole, or leave it and lower your price by $15K.
To some, your logic is the type only a third grader would come up with because only a third grader couldn't see through it. Peddlers love it.
But all that's of topic.
"As of the second quarter of 2016 more than 1.1 million solar photovoltaic (PV) homes exist in the US. Capturing the value these PV systems add to home sales is therefore important. Our study enhances the PV-home-valuation literature by analyzing 22,822 home sales, of which 3,951 have PV, and which span eight states during 2002–2013. We also, for the first time, compare premiums with contributory value estimates derived from the present value of saved energy costs (income approach) and, separately, the replacement cost of systems at the time of sale (cost approach) to examine market signals. We find home buyers are consistently willing to pay PV home premiums across various states, housing and PV markets, and home types; average premiums equate to approximately $4/W or $15,000 for an average-sized 3.6-kW PV system. We find that a replacement cost net of state and federal incentives is a better proxy for premiums than gross installed costs, and that the income approach is a good signal if it accounts for tiered volumetric retail rates. Other results include detailed premium analyses for PV home sub-populations"Leave a comment:
The poster here is talking about purchasing a solar panel system. Let's say you have two homes which are exactly the same, except for the fact that home A has solar panel system and home B doesn't have solar panel. Let's say over the next 10 years you are going to pay $15k less in electricity bills living in home A. A rational buyer will pay more for home A with solar because they will have to make $15k fewer payments to the electric company. This is logic a third grader could understand.
Homes will solar sell for 4.1% more, on average in the USA, than homes without solar. https://www.zillow.com/research/sola...ll-more-23798/
Please show me any study which indicates that homes with solar don't sell at a premium, not just some anecdotal story.
But all that's of topic.Leave a comment:
What does common sense have to do with it? I think you've been drinking the solar salesman Kool-aid.
Around here, few home appraisers give any value to having solar, even if the panels are owned free and clear. Solar on the home is often a bargaining chip for the buyer to get seller concessions because there is often a lease transfer involved.
Please show me any study which indicates that homes with solar don't sell at a premium, not just some anecdotal story.Leave a comment:
Thanks for the responses. Appreciated...Leave a comment:
