Good evening guys.,
Something happen to my XW6848+ two days ago. The Load Shave function no longer work. Sunday We have 6 error message on the grid support XW4848+. AI over Frequency for 6 times during the day. after that I can't get the Load Shave feature to work. I have installed this system for one year now since Last year February. It was work perfectly for the whole year. now it stop work. I still can sell to the grid and during the sun shining hours It still use solar power to supply my house load and draw some current from the grid if the clouds pass by. but in the evening it just pass through the grid power to supply the load, only if I turn off the breaker from the grid it use the battery to power the load.
Any one know what is going on? I turn off and on the inverter few times still the same. I don't want to reset to factory setting as my inverter come with 60Hz by default I have to pay someone to program it to 50Hz in order to work with my grid. I don't know if I reset it to factory settings would changed back to 60cycles and I won't to able to change it as I don't have the configuration tools.
Does any one know what cause the problem?
Thanks in advance
Thanks in advance
