Assume you have a grid-tie inverter (solaredge) and want to add a 2nd system that's a hybrid with ability to generate power if the grid goes down. The 2nd system would provide power off the array during sunlight and run off battery in the eve for bare essentials.
What recommended hybrid systems for 6-8kw are there?
Whats my options to engage the hybrid on manually or if possible automatically?
With the Grid Tie off and Grid disconnected, can The hybrid drive just Daylight array generation without a battery system?
if disconnected from the Grid and the Hybrid is powering the home, can the Grid Tie Inverter be connected and sense the AC output by the Hybrid and turn on its ouput and provide additional power separately?
