Hello,
I just bought a new MPPT charge controller made by Epever to charge 24V battery bank at 215A (4x6V GC2 from Sam Club) using two 315W panel in parallel.
By the default, Epever CC has Flood battery configuration set as:
Please let me know what is the best setting to keep the battery life as long as it can be.
Regards,
Key
- Over voltage disconnect: 32V
- Charging limit voltage: 30V
- Over voltage reconnect: 30V
- Equalize charging: 29.6V
- Boost charging: 29.2V
- Float charging: 27.6V
- Boost reconnect charging: 26.4V
- Low voltage reconnect: 25.2V
- Low voltage disconnect: 22.2V
- Discharge limit: 21.2V
- Equalize duration: 120 min
- Boost duration: 120 min
Regards,
Key
