OutBack Battery-Based Inverters from 2017)
Grid Tie Inverter Compatibility
OutBack Power has successfully tested our AC coupling solution on SMA, Enphase and SolarEdge inverters.
SolarEdge does not support blackout relay solutions, but has something called a Power Reduction Interface Port
that can be used instead of a blackout relay to take the inverter offline.
