The right mppt cc for me
  • Floating down here
    • Nov 2017
    • 14
    hi all, I've checked the threads and can't find an answer so perhaps someone can assist me. I have 4x 190w pv array (760w) total to charge a 24v 150ah battery bank. These are the specs:
    Pmax-190 (24v)
    Vmp-36.6v
    Voc-45.2v
    Imp-5.2a
    Isc-5.62
    i want to configure them in parallel to give me the following:
    760w
    36.6v
    20.8a
    by these calculations (if correct) the total amps (as represented by the Imp of 5.2a x4=20.8a)gives me the output current of the array (+25% =26a for extra light/reflections etc)
    So I determining the right mppt charge controller am I correct in assuming the 26a output is related to the max amp a CC can take? IE: a 30a model like the tristar 30 or MidNite solar the kid?
    The reason I'm confused is because I've read that to find the right amp CC you should take the total watts of the system (760w) and divide by the battery bank voltage (24v)
    760/24=31.6a +25%=39.5a
    significantly higher than the current at Pmax (20.8a) requiring a larger CC.
    any ideas?
    Yes, MPPT controllers are rated at output capacity. 30A at whatever the battery charging voltage is.
    But your problem is that 36V is not likely to be enough voltage to allow the controller to work in the MPPT region, and it may simply charge as PWM because a 24v bank, needs to charge at nearly 30V. When panels get hot, you may get 34 or 33 volts from them. I like to run battery charge voltage x 1.5 to get my min PV array Vmp , So wiring your array to 45V would be a better way to insure MPPT activity.
    Also, the major controller manufactures, have a Size Calculator to verify your expensive gear will work right.
    Kid http://www.midnitesolar.com/sizingTool_kid/index.php
    Classic http://www.midnitesolar.com/sizingTool/index.php
    Morningstar http://string-calculator.morningstarcorp.com/
      • Nov 2017
      • 14
      Thanks Mike90250, I will endeavour to use those calculators at a more acceptable hour here. I'm a little curious, how would I wire the array to 45v?
        I don't know what your panel voltages (Vmp) and amps (Imp) are, you may need to wire 3 in series, or only 2 depending on the voltages of the panels. Tell us the Voc also, it's very important too.
          • Nov 2017
          • 14
          Pv info (each)
          I have 4x
          pmax-190w
          output tolerance- 0/+5%
          Imp-5.2A
          Vmp-36.6V
          Isc-5.62A
          Voc-45.2V
          TNoct-45
            • Nov 2017
            • 14
            Perhaps configuring them as 2x series/ 2x parallel? Would this solve the problem?
            cheers again Mike.
              2S,2P is the route I'd go, to utilize a MPPT controller. 2S will give you nearly a 100V open circuit, so the small 75v controllers are out. 25A is a reasonable expected output, so a 30A controller would work. Run the thermal on the string sizers, and make sure they don't exceed the controllers specs on a cold day
                • Nov 2017
                • 14
                What is meant by "run the thermal on the string sizers"?
                • neweclipse
                  • 118
                  To make sure they don't exceed the controllers specs (for peak voltage) on the coldest day at your location.
                  That is a temperature that only you would know for your area...input that temp into the calculator(s) with everything else required.
                  Excess "open circuit voltage' above MAX can destroy a CC.
