Thanks pellets4fuel. I have done the calculation. The wire can handle it. I am still a bit unsure about wiring up to 16 340 watt, 39 v panels. In series the voltage could exceed the 600 volt charge controller, and it appears, (but I'm not sure) that running 2 strings in series then parallel is not the best. The extra cost to go from 12 to 16 panels, is not much, and I add 25%, which would be a bonus in the winter.
I am looking at both the 600 v charger controllers but I think it will be morning star. As for the question about midnight solar, I prefer less moving parts whenever possible..
Advice on getting power 250ft to batteries
Na, No crying, just made me wonder... 😁Leave a comment:
Morningstar silent, no fan. Midnight has 3 fans.
I've heard the Schneider 600 is good too. If you have one of the 3, don't cry.
I'm as new as new gets to solar energy, and I enjoyed this thread too.
One thing that stood out in the first post was anything but Midnight Solar.
Is there a problem with them?
You guessed it, I own one...
pp4x4Leave a comment:
Morningstar and Schneider also make 600V charge controllers.Leave a comment:
Gord,
Midnight solar has a nice online calculator to see what size CC to use given different panel configurations. They take into account the temp coefficients that come into play for when your kicking out more power in colder weather. It's not just about the panel tag says under standard test conditions. Keep your volts up, and amps down to keep line size smaller and efficient. That 600v Mppt is a little more costly than Midnight 250 if it would work after checking the sizing tool. I am far from being smart enough to give advice. I am still learning myself and am finally going to build an experimental system in my shop this spring. About 1500w of panels with a 1200w wind generator. I too have the issue of almost the same exact distance as you that's why I was reading your thread, to help with my answers, and see what advice you got. I still need to read and educate myself more on the relation ship of size of batteries to input available as to have enough to keep X amount of amp hours charged. Good luck with it all!
DavidLeave a comment:
There is your answer..."We will be using a 600v charge controller."
Higher the voltage, the lower the current.Leave a comment:
I wouldn't call it agonizing, but did and do have some concern about the copper. I don't want to waste it if I can use it.
We have weather variations form -40 to +90 f Rarely over +80, and a few days each year below -40 daytime.
I will watch the "wordy" Very valid point. I've been told before.
You can criticize, or give me words of wisdom, "Your choice" I'm a big boy, I can take it. The latter would be much appreciated.
My average panel production will be approx 1240KWH? per year for 1kw of panels with December being the low of 720kwh/yr
Our plan is 6-7 years part time power, then up grade battery, inverter, etc. .Add to these panels our add another string.Leave a comment:
Not doubting your word, but, you built 6-7 homes and yet agonize over a piece of discounted copper...and, oh, wordy, yes.Last edited by neweclipse; 02-20-2019, 01:43 PM.Leave a comment:
Thanks Ampster. After your suggestion, I checked on and decided that conduit will go in the ground. My commitment to 6 awg, is quite simple the 6 became available for $100, many times more $ to buy even at wholesale, the difference pays for the charge controller. and if 4, awg becomes available it will go in the ground. Maybe they will both go in the ground whether it is 4 or 6, if it makes sense, and more becomes available. The panels are frame-less. the best price I can find per watt, and are of good quality, I think.
I'm just trying to save money wherever I can, and learn whatever I can in order to make buying, and installation decisions, and at least have some basic knowledge, as I know solar is not just a plug it in and forget it proposition. We have a pretty ambitious year in front of us, that includes the solar/genset, finishing the cabin, building a self watering garden that's protected from the critters, and burying a sea-can underground, for canning, potatoes, and other food preservation. The sea-can will also provide weather protection should we ever need it. My wife and I have both lived thru a big tornado up here, and the cabin is on screw piles.There is a little more to our goals this year, but I don't want to be be too boring.
15-16 panels 1 string 570 volts @9 amps or 2 strings in series then parallel?
16 - 20 panels same question,
Look up the string calculator for your controller and try different configurations. Your 15 - 16 panel string and higher count strings will likely be too many panels. The panels Voc. voltage is used for these calculations factored with the lowest expected temperatures for your area.
I can buy a 1 or 2 pole mount that will handle up to 20- KuDymond 144 cell, 340 watt, 38 volt 9 amp panels. Does it make more sense to buy a 20 panel system right now, at 50 cents per watt due to panel longevity? I prefer to keep my upfront costs down to start with less. then add in 6 years. What would you do?
If you were going to wire how would you do it?
10 to 12 of these panels 38 volt x 12 = 456 v @ 9 amps 1 string in series, or 2 strings 228 v @18 amps. not exact but close?
I agree with your comments and appreciate what you're writing. Some of what I contributed to this thread was way off track. As a way of atonement, after this thread, I'll not be wasting any more of your time by my spreading my spoor over this or any of your future threads.
As for education, and no more than my opinion, this forum is a good place to fill in the cracks created by real self education. Better questions get asked that way and they tend to be fewer in number. That's also considerate to other posters who won't be as frustrated answering questions a poster could answer for themselves. IMO only, that's a matter of consideration and respect not only for others but for questioner as well. The informed questions then act similar to mortar to fill in the cracks created by the self education, but the uninformed questions do not necessarily produce a good foundation or a first source of knowledge.
To that end is why I suggested you get informed about PVWatts. It's a good start on what you might need and one way to get information on things you mentioned in the first paragraph of your first post to this thread. Take it for what it's worth. There are also many good books dealing with residential solar PV design for both on and off grid. Google is your friend.
As for your frustration, I feel your pain , but maybe as one who sees the uninformed stumbling around in ignorance and unwilling to do a little reading on their own and then I wind up as cannon fodder when an attempt is made to help out with some things that may be useful but that the ignorant in their lack of knowledge find intrusive and off topic. In such cases I've learned to pick and choose which posts I read and ignore the ones where I'm ignorant of the subject matter and so possibly dangerous.
Since I'm not in the business of knowingly pissing people off, I'm afraid I'll need to decline your request for any further information. Sorry I wasted your time.
Good luck in your future endeavors.
You could have advised 10 or 12 panels wired this way, or that way would work with the wire, and run length, or in contrast,,,, it will not work.
FYI I have a file folder over an inch thick. The first thing I did, which was quite some time ago, was to determine my worst case month, December, as you advised above. I can achieve this with limited panel production, and back up generation.
I also went to calculator.net to get an idea of the wire I bought, for this application, using a 600v charge controller.
I was hoping for some real world verification, and advice on how best to wire the panels.
I am sure you don't think about or care about wasting my time with your spoor, but rather you do not want to waste your time by answering questions of the unworthy, like me.Leave a comment:
My time was not wasted, and I wasn't t pissed off. I do apologize if I offended anyone. It was not my intent. I realize that people have varying opinions, about virtually every subject there is. The term "more then one way to skin a cat" applies to everything. If I can make this cable work, I would like to. 6-4-2 cable is not cheap up here.I can put the money saved elsewhere in the system. I'm working on that premise with the panels, and the Battery as well. These 3 areas are where I know I can save money. Possibly pole mounts as well. As I mentioned I am looking for good 3 season power supply, with some propane back up, for the next 6-7 years.
I am learning this morning.
Ampster your comment about a second string in the future got me thinking. My trenching costs me fuel, a few beers, and some food. My nephew has the equipment. I'm not concerned about possibly digging another trench in 6 years. I'm sure my buddy would be happy to keep an eye out for more new cable scrap. I think in 6 years he will find something. if he does I will buy it and store it. If I don't use it I will pass it along to someone else. If by chance he finds a suitable length of bigger cable before spring i will use that, but 6 awg is where I'm at right now..
The money that I could save by not buying another cable, could buy 6-8 more panels, could buy me more battery capacity, could buy more inverter, or other related components. I prefer to keep the costs down while buying and installing enough to do the job.
Let me ask more specific about panel wiring configuration, with the premise that the long run 6 awg wire is my only option. 6 to 7 years for batteries, and inverters, etc is my consideration.
5kw would be more then enough with everything turned on and running.
J.P.M Thanks for that advice. I will take the steps needed to get my direction, and various tilt angles as right as I can.
I hope to stay on the topic of the thread I started, and still hope for some direct answers to the questions I asked. I want to know opinions on the 6awg wire I have, and will it work? If so how should I wire the panels to work best thru the cable, and for the charge controller. I have to admit it is a bit frustrating to ask direct questions from those that know, then to read more side tracks then answers. I thought i would break down my questions into segments, starting at the source, the panel configuration, the long cable run, and the charge controllers ability to to get the batteries charged especially in winter. I will have other questions about, safety components, inverters, monitoring etc. I think I'm on the right track battery wise, but if not it would be great to know before I start this spring.
I am on a couple firearms/hunting related forums, and like to think I know my stuff pretty darn well. I purposely look for people who ask questions trying to gain knowledge, of various aspects, then try to answer their questions, and stay on the topic of the OP. I find it very interesting, and still learn a few things as I go. As you know, my knowledge in the topic of solar is very limited. I am the type of guy that likes to learn. If I had unlimited funds and could simply phone a couple companies, and tell them i want an expendable 15kw system, I still wouldn't without basic understanding. Please give me the benefit of your knowledge. I think with it I can achieve a good well designed system, at a price that I can afford.
Thanks Gord
Good luck in your future endeavors.Last edited by J.P.M.; 02-19-2019, 11:40 AM.Leave a comment:
