How to calculate amp load based on watts for 12v system?
  • SunSeeker1
    • May 2018
    • 24
    My 230v inverter shows the load of the fridge plus fan at 140w. If I want to calculate how much amps this load is drawing from the battery do I do 140 divided by the pv voltage (eg 16v) or by the battery voltage (eg 13.1v) or just by 12v?
    I know the load is 140/230 = 0.6 amps but I want to figure out how much is being sucked out of the battery.
    AC watts * 1.2 (80% efficient inverter) = DC watts so 140 *1.2 = 168dc watts / 13.1v = 12.8 amps dc or something pretty darn close
    I used your battery voltage, but generally, I would us the baseline bank voltage 12V and build a little extra bit of margin into the calculation.
    • SunSeeker1
      • May 2018
      • 24
      So which is more accurate to use battery voltage or system voltage with a margin of error (what's the margin exactly?)
        Nominal battery voltage is what you want to use, 12 volts. You want to use worse case. Electrical we measure with a micrometer, mark the spot with chalk, and cut with an axe.
        • littleharbor
          • Jan 2016
          • 1998
          Fire up the diesel generator to charge my flashlight batteries.
