So I'm trying to figure out how exactly to value a particular kWh produced/consumed for me which just grandfathered into E-6 (closing end of month) and NEM 1 (closing by October).
Here's a good page on figuring out what energy is worth with this complicated setup they give us
First my question then a summary of how I believe it works. When you 'sell' (get credit) for exporting kWh, those are at the non tiered current customer price, correct? So if I am exporting 1kWh at a time where buying a kWh is 20 cents, then I'm getting a 20 cents credit, and that exporting is always at baseline price (not tiered)? But I buy at my tiered rate.
Otherwise here's the short version of my understanding
- You buy at your tiered rate, but if you have a well-sized system your tier is always baseline
- You always sell at your baseline rate (I believe)
- However E-6 TOU is best because you sell at highest rate during day and buy at lowest rate at night (>2X)
- PG&E holds on to about $10 every month from you until True Up
- However if you’re running a deficit, as you usually are when system is sized to 80%, you owe more than that anyhow
- Getting to roll over credit really pays off, you generate excess in the summer and use that in the winter
