Any tips for simplified approaches for estimating the impact of TOU rate/period changes on PG&E? With baseline + tiers complicating the matter? Or to quantify the error margin a bit? A straight revenue based approach tells me something, but not sure how off when how my baseline is allocated is affected so much by usage.
TOU revenue calculator
Take this for what it's worth: From my experience, the only way to get close to accuracy in a $$ estimate based on usage is to understand and duplicate the rate tariff you will be using with a spreadsheet or other tools. Small calculation errors often produce large bottom line errors. I have not found a simple way to get reasonable accuracy. Most tools from models and others (vendors) are inaccurate, either in method or are out of date.Any tips for simplified approaches for estimating the impact of TOU rate/period changes on PG&E? With baseline + tiers complicating the matter? Or to quantify the error margin a bit? A straight revenue based approach tells me something, but not sure how off when how my baseline is allocated is affected so much by usage.Comment
Are you looking at E-6? There was a detailed breakdown of how PG&E portions out the baseline allocation into the TOU periods in this post, with a few more examples later in the thread:Any tips for simplified approaches for estimating the impact of TOU rate/period changes on PG&E? With baseline + tiers complicating the matter? Or to quantify the error margin a bit? A straight revenue based approach tells me something, but not sure how off when how my baseline is allocated is affected so much by usage.
https://www.solarpaneltalk.com/forum...754#post122754
It was complicated enough that I didn't try to adapt other TOU calculators I had built, but I'd 2nd J.P.M.'s suggestion to put in the effort if you want an accurate calculation.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
