Hi Everyone, I just got my system up and running two days ago so I have been monitoring things rather closely. At night I am noticing the following problem. My Battery is over the course of 3 hours dropping almost an entire volt from 13.6v+ down to right now about 12.8v. However, absolutely nothing is plugged in or on. In fact I disconnected my power inverter from my battery this morning wondering if the inverter was drawing voltage when turned off. I have been monitoring my voltages tonight and it had the exact same voltage drop with the inverter still disconnected. Can someone explain whats going on?
My Setup:
1x 48volt 250watt solar panel into an Tristar MPPT 60 Charge Controller down to 1x 12 volt 170 (200) amp hour AGM battery, then through a 250amp fuse to a 2000watt Xantrex Puresinewave Inverter. Wiring is all 4AWG Out of the inverter through the rest of the system.
I know my inverter is way overkill right now, I plan on upgrading batts and panels in the future.
Questions?
1) Any ideas as to what I am seeing?
2) Does the Tristar MPPT serve as basically blocking diode to prevent back current draw from the battery to the panels? If not is the loss I am seeing the panels drawing power @ night?
3) What can I do to limit / stop this drop as that is a massive drop for a battery to take every night over a few hour period with no load in the system.
Thanks for any help or advice you can offer.
My Setup:
Questions?
