Pls help me understand a current for MPPT charge controller
  • New_Climber
    • Nov 2012
    • 18
    I was hoping you could help me understand what the “max battery current” rating is for a MPPT charge controller…
    I am looking at the Morningstar SunSaver 15 Amp MPPT Solar Charge Controller, I currently have 2-185w, 36v(44Voc) panels. I have not purchased any batteries as of yet.
    I am looking to have this system run some overhead LED or CFL A/C lights in a garage. So, I understand I will need a inverter also.
    My question mainly is, what and where does the 15amp part of this controller mean? Is it the current that the panels are producing? If I calculate the current (185w*2= 370w/36v) I can produce about 10amps at max production. If I decided to go with a 24v battery system, how does this factor in.
    In looking at any MPPT or even PVM charge controller, what does the current rating mean.
    Thx for the help…
  • Naptown
    • 6880
    that is maximum current to the batteries.
    So you have 370 Watts maximum from the panels
    370/24= 15.1A
    You do lose about 5% so this should be all right. However there is no room for expansion.
    • New_Climber
      • Nov 2012
      • 18
      370/24= 15.1A
      So when calculating the max current the charge controller can handle, the Voltage of the panels is not considered...just what the voltage of the battery setup. So in my situation, I could NOT use this controller if I was to use a 12v battery setup...is this correct? (370/12=30amps, to much for this charge controller)..
        Not from the POV you are referring too. For MPPT controllers it is in reference to the output to the batteries.
        Correct a 15 amp MPPT has a maximum power input of roughly 15 amps x 12 volts = 180 watts.
