You can get into the Ball Park by Amps = [AC watts / Battery Voltage] / Inverter Efficiency.
So if your puter draws 300 watts from the inverter, the inverter efficiency is 90%, and battery voltage is 12 volts then [300 watts / 12 volts] / .9 = 28 amps. So the battery is supplying 12 volts x 28 amps = 336 watts. What it does not account for is the wiring losses and some inverter non linearity issues. But it is close.
For giggles and grins get you a 50 amp shunt and install it between the battery and inverter. You can then monitor the battery discharge current in real time with a volt meter. Something like this minus the shunt on the left..
